assembly programing
![[Deleted User]](https://images.v-cdn.net/banned_large.png)
·I'm trying to add 2 numbers together & display them out the debug term , the debug is working fine , but I get a little smilie face where my answer should be.
Thank's Brian
'' *· PC_Debug_Test· *
CON
· _clkmode····· = xtal1 + pll16x······················· ' use crystal x 16
· _xinfreq····· = 5_000_000···························· ' external xtal is 5 MHz
· CR··········· = 13
· FF··········· = 12
· LF··········· = 10
· Space········ = " "
OBJ
· debug : "pc_debug"
PUB main
· debug.start(460_800)································
· debug.str(@title)·
· debug.crlf
· debug.dec(@total)
· debug.crlf
· debug.crlf
· debug.stop
dat
title·· byte·········· "Assembly programing test ",0
total·· res·· 1
······· add·· first,#second
······· mov·· total,#first
first·· long· 2365
second· long· 6985
Thank's Brian
CON
OBJ
PUB main
· debug.crlf
· debug.dec(@total)
· debug.crlf
· debug.crlf
· debug.stop
dat
total·· res·· 1
first·· long· 2365
second· long· 6985
In your simple test, the first instruction adds the address of "second" to the contents of "first" rather than the contents of "second". Try leaving out the "#" to do what you probably want. Similarly, the second instruction will move the address of "first" to "total" rather than the value of "first".
You can copy values into a DAT section using an assignment and they will be copied to the cog's memory by the COGINIT/COGNEW, but you can't get the values out. The "@total" refers to the location in the DAT section, not the contents of the corresponding cog location. Typically, what people do is pass the address of a main memory variable in the PAR register (as the second parameter of the COGINIT/COGNEW statement). Then they use a "WRLONG address,PAR" to copy the contents of "address" to the main memory variable where it can be displayed.
Your brief program will need a way to stop itself. The best way is to have some temporary location "temp", then do a "cogid temp" followed by a "cogstop temp". You could just have a jump instruction that jumps to itself, but the cogstop turns off the cog so it doesn't take any significant amount of power.
CON
var
······· long········· stack[noparse][[/noparse]9]
······· byte········· cog
······· long········· total
OBJ
PUB main | temp
· COGNEW(cog:=@addfor, @total)
· debug.crlf
· debug.str(@total)
· debug.crlf
· debug.crlf
· debug.stop
· cogstop (cog)
Dat
······· ORG·· 0
title···· ··· byte·········· "Assembly programing test ",0
addfor··· · add·· first , second
············· wrlong· total , first
first·········long· 2365
second···· long· 6985
total······· res·· 1
Thanks Brian
Post Edited (truckwiz) : 12/3/2006 3:29:33 PM GMT
·Here's the code.
Thanks , Brian
Post Edited (truckwiz) : 12/3/2006 3:17:36 PM GMT
·I'm pulling my hair out , I redid the code to place the result in num_1 . I get the number that was in num_1 , so· I added another VAR , now i have the same problem I had with the first code.
Thanks , Brian·····
Post Edited (truckwiz) : 12/3/2006 6:50:11 PM GMT
Notice that your program never called AddNums so the assembly stuff was never executed. It's very important ... The first public method (routine) in the main program is what gets executed when you start the Propeller. Nothing else is executed unless it is called by that method or some other method called from the first public method. Methods that are not called directly or indirectly by that first public method are not even loaded into RAM or EEPROM by the Propeller Tool.
·Thank's for your help ! I have to say that when I started with trying to get the propeller to add & display the results in assembly , I didn't think it would take that much code . Heres my code to do it in just spin .
Thanks , Brian··
CON
OBJ
PUB main
· debug.str(string("spin testing"))
· debug.crlf································
· debug.dec(5632 + 9658)·
· debug.crlf
· debug.stop
·This might sound like a stupid question·. But how come you don't have to fire·· another cog up for spin or is that the only thing that cog does?
Thank's Brian
CON
OBJ
PUB main
· debug.crlf
· debug.str(@total)
· debug.crlf
· debug.crlf
· debug.stop
dat
Thank's Brian
One cog gets loaded with the SPIN interpreter from ROM (another I/O device) on a master reset. There's nothing requiring any other cog to be used. If your application needs the speed or parallelism, it can force another cog to be started either with the SPIN interpreter or an assembly language program you supply. If it's the SPIN interpreter, it executes a method (routine) you specify that it finds in RAM. Since SPIN code is read-only, two (or more) interpreters can interpret the same routines at the same time. You have to provide logic to keep the two (or more) interpreters from changing common variables at the same time (if they're not supposed to do so).
·Works awesome! Do you have to notify parallax·when you modify a object (I redid LCD so that it would display dec , hex & bin). My next step is to try to display the flags. I haven’t had time to check into that yet. how does par know to save results in Num3 ?
Thanks, Brian
Post Edited (truckwiz) : 12/6/2006 3:57:29 AM GMT
Look at the description of the COGINIT instruction in the assembly portion of the Propeller Manual. When you do a COGINIT/COGNEW statement in SPIN, the interpreter ends up doing a COGINIT instruction. The second parameter of the COGINIT/COGNEW eventually ends up in the PAR register of the new cog. The low order 2 bits get forced to zero which is usually ok because this is normally used as the address in hub memory of a long word. In the case of your routine, "@Num3" is used as the 2nd parameter so the assembly code will have the address of Num3 in the PAR register.
I'll answer the first part of my question so nobody else has to swear at me . Brian , make sure that there is not already a object that does what you want it to do before you modify other objects !
Thanks, Brian
Post Edited (truckwiz) : 12/6/2006 3:56:23 AM GMT
