Can't get the Javelin and BS1 to communicate with the 433 MHz RF modules
Hi everyone,
For my senior design project, I'm working on an RF-based security system. I'm trying to make a BS1 send back the status of a reed switch over one of the 433 Mhz RF transmitters. I've been starting off by modifying the sample programs from the spec, but I can't get the Javelin to correctly decode the info from the BS1. This is my modified Java Receiver source code, and the BS1 code for the transmitter is right after it:
public class RFmoduleRxTest {
static Uart rxUart = new Uart(Uart.dirReceive, CPU.pin15, Uart.invert, Uart.speed2400, Uart.stop1);
static StringBuffer buffer = new StringBuffer(128);
static byte c;
static byte x=0;
static byte y=0;
static void bufferMessage() {
c=0;
do {
c=(byte)rxUart.receiveByte();
} while(c!=33);
x=(byte)rxUart.receiveByte();
y=(byte)rxUart.receiveByte();
public static void main() {
System.out.println("Hi");
while(true) {
buffer.clear();
bufferMessage();
System.out.println(x);
System.out.println(y);
' {$STAMP BS1}
SYMBOL x = W1
SYMBOL y = W2
Start:
PULSOUT 14,300
SEROUT 14, N2400, ("!", B3, B2, B5, B4)
PAUSE 100
x = x + 1
y = y + 1
PAUSE 150
GOTO Start
I luckily have two Javelins and two super carrier boards to play with, so I can get two Javelins to talk to each other, but nothing I do can make the Javelin understand anything coming from the BS1. I've been modifying baud rates and adding delays, but nothing seems to work!
I would greatly appreciate any help anyone could provide; my project is due soon, and I've been stuck on this for the last two weeks.
Thanks!
static byte c;
static byte x=0;
static byte y=0;
c=0;
do {
} while(c!=33);
while(true) {
buffer.clear();
bufferMessage();
' {$STAMP BS1}
SYMBOL x = W1
SYMBOL y = W2
Start:
PULSOUT 14,300
PAUSE 100
x = x + 1
y = y + 1
PAUSE 150
GOTO Start
Thanks!
static byte c;
static int x=0;
static int y=0;
c=0;
do {
· c=(byte)rxUart.receiveByte();
} while(c!='!');
x=(byte)rxUart.receiveByte();···· //low byte
x |= (rxUart.receiveByte()<<8);··//high byte
y=(byte)rxUart.receiveByte();····//low byte
y |= (rxUart.receiveByte()<<8); //high byte
while(true) {
buffer.clear();
bufferMessage();
' {$STAMP BS1}
SYMBOL x = W1
SYMBOL y = W2
Start:
PULSOUT 14,300 'required for RF transmitter
SEROUT 14, N2400, ("!", B2, B3, B4, B5) 'send low,high,low,high @2400baud true mode
x = x + 1
y = y + 1
PAUSE 250
GOTO Start
Edit: just realised the pulsout is required for the RF transmitter
so the·error·was probably the assembly of the x and y which should be ints
as in the code above.
regards peter
Post Edited (Peter Verkaik) : 12/3/2006 6:45:43 AM GMT
I tried the new code; the Javelin still can't decode the info from the BS1. I've checked the antennas and the BS1's, so I am confident the problem is not hardware-related. I have a feeling that it has something to do with the order in which the Javelin's receiving the data from the BS1 (maybe it's receiving everything in backwards order?)
This is the output from the message window, which I captured right after resetting the Javelin:
Hi
-10
-66
14
14
15
15
-68
-120
-2
-80
-99
-40
-4
-96
-25
-29
18
18
-107
-6
19
19
-43
-48
21
21
I have however, been able to get the Javelin to transmit data to the BS1, and the BS1 decodes the info properly. If it provides any insight into the problem, this is how I accomplished it:
import stamp.core.*;
public class RFmoduleTxTest {
static Uart txUart = new Uart (Uart.dirTransmit, CPU.pin14, Uart.invert, Uart.speed2400, Uart.stop1);
static byte x=0;
static byte y=0;
while(true) {
if (x>=10) x=0;
else x++;
if (y>=10) y=0;
else y++;
/*x++;
y++;*/
CPU.pulseOut(300, CPU.pin14);
txUart.sendString("!");
txUart.sendByte(x);
txUart.sendByte(y);
CPU.delay(3000);
' {$STAMP BS1}
SYMBOL x = W1
SYMBOL y = W2
Start:
SERIN 1, N2400, ("!"), W1,W2
DEBUG B2, B3, B4, B5 'B2 and B4 contain the low bytes, while B3 and B5 contain the high bytes
GOTO Start
Thanks again!
You send 2 bytes with the javelin and the bs1 must receive 2 words,
which are 4 bytes.
regards peter
Thanks for all the help!
static int c;
static int x=0;
c=0;
do {
· c=rxUart.receiveByte();
} while(c!='!');
x=rxUart.receiveByte();
while(true) {
buffer.clear();
bufferMessage();
' {$STAMP BS1}
SYMBOL x = B2
Start:
SEROUT 14, N2400, ("!", B2) 'send values 0-255 @2400 baud, invert mode
x = x + 1
PAUSE 250
GOTO Start
The javelin should print
0
1
2
255
0
1
etc.
regards peter
