How to make your own PCBs at home
ALIBE
Over the last couple of weekends, I have set myself to explore learning making PCBs at home. This might be very trivial to most of the advanced folks in this forum. It was definitely very new to me and had a lot of fun learning and experimenting a few times.
I wanted to share my excitement and my experience in this forum. If in case folks like me who might want to do similar stuff in their own projects.
I could have definitely chosen the route of picking online PCB makers, but, before I did that,· I wanted to try and make them myself. I think I learned something and it was a lot of fun.
Here's the url to the step-by-step - in my own words [noparse]:)[/noparse]
http://aliben.wordpress.com/2006/12/02/41/
all comments and feedback are welcome
ciao
"any small object, accidentally dropped, goes and hides behind a larger object."
ALIBE - Artificial LIfe BEing. In search of building autonoumous land robot
http://ALIBE.crosscity.com/
ciao
I didn't check the webpage......but I'm sure you learned a lot from your experience......I've never tried making one myself. Always had someone route it or a pcb house make it.
James L
One way to get the etching over with a bit quicker is to place the plastic tray in a hot water bath.
Don't visit my new website...
LSB, thanks. The first attempt I tried w/ "silk" setting and that did not transfer the toner ink from the p-n-p to the PCB that well. Second time around,· I turned it up to Wool and that seemed to have worked well.· As w/ regard to start-to-finish, it took me 35 mins. The first attempt it took me 45 min. So, the 2nd attempt proved a bit quicker (and hopefully better)
Gadgetman, thanks - I must try the hot water bath next time. I heard it speeds up the etching process - but did not think of trying it. Thanks for bringing it up - I will try it next time for sure. Hopefully, that will bring down the start-to-finish time quicker.
I think I like the printer method better, a much cleaner looking job.
Looks great, thanks for the info
Josh
I would defintiely be interested in the SMT tutorial, please post when you have it ready to share
No a ground plane (copper pour).....you leave all the excess copper with traces isolated by small thin valleys between the traces and ground plane.
Like the one included here: ( the picture is not great.....but trust me it is perfect and clear)
James L
Post Edited (James Long) : 12/2/2006 9:12:53 PM GMT
How does one solder parts to this - are these only meant for SMTs. Can you share a few examples.
thanks
Your thoughts?
thanks!
Most ground pours are for the bottom side. My picture is of a bottom pour. I do not suggest a top pour with homemade pcbs. Remember you don't have a solder mask to keep solder from running everywhere. You can however have top and bottom pours if you have a board made with solder mask.
Solder Mask BTw is a preventative film that only leaves the pad open to accept solder. (In case you don't know.)
A bottom pour is very reasonable on homemade PCD's because very few people place components on the bottom side.
James L
that was very good information. I will do some learning on this front and possibly give it a shot
