Volts
Could I run the 1.8v-only Propeller from 1.5v at the cost of perhaps not running at maximum speed?
EDIT:· I don't know how this post got out of the obvious thread it belongs in.
I would say from a limited experience with chips of this voltage. You would be hit and miss running at 1.5 volts. You may be able to run it ......if you power was absolutely stable. If you fluctuated ANY it would probably reset. I would think 1.5 volts is close to a brown out situation.
Chip can anser this better than I.
James L
