General Solenoid Question
I just bought some solenoids and am having trouble just turning them on.· I have a power supply setup for 12volts and when I apply the voltage to the solenoid's leads nothing happens.· I hear a short click and it draws current, but the plunger never moves (I do have the voltage polarity connected correctly).· Here is what it says on the solenoid:
Dormeyer Industries
Part NO: C8-2178
Voltage: 12 VDC
Duty: Pulse
22 SEP 94
Does "Duty: Pulse" mean I have to give it a pulsed signal or something like that?
Thanks for the help,
Jared
Dormeyer Industries
Part NO: C8-2178
Voltage: 12 VDC
Duty: Pulse
22 SEP 94
Jared
2) A lot of solenoids [noparse][[/noparse]most?] are of the "pulse" or momentary, variety.··They're designed to be energized briefly, as opposed to a "constant duty" sort which can be energized for a long time.
I'll try calling the place I bought them from and ask if they have experienced this before.
Jared
· Do these supplies go below 12V then?· That's not good.·
· You can connect a solenoid to a voltage that's less than required and it'll click and so on (as you've noted), but it won't work/actuate.
The initial current demand of a sturdy solenoid can be quite high. You may need a large capacitor to "stiffen" your power supply's output and take the initial current demand. After that, I suspect your existing power supply will probably be able to handle the current demand, so long as it's intermittant duty and not continuous duty.
I'm sure one of the electronics guys can recommend a size for the capacitor based on the characteristics (voltage, amperage, resistance) of the solenoid in question.
Bruce Bates
<!--StartFragment -->
Thanks a lot for the help guys,
Jared
Post Edited By Moderator (Aristides Alvarez (Parallax)) : 12/18/2006 4:53:07 PM GMT
