Propeller boards
I've been on the drawing board again.· I have laid out a new Propeller board which eliminates some of the shortcoming on my first board.· They are Expresspcb boards and I get three, of which I only need one.· So....
I would like to sell the other two.· Here is a description of the board:
Size· 3.8 x 2.5
5V and 3V regulator
DIP Prop
Vga connector - Pins 8-15
One PS/2 connector - Pins 26 and 27
2 x 3 female header - 3V and ground
2 x 3 female header - 5V and ground
8-pos female header - Pins 16-23
2-pos female header - Pins 0 and 1
6-pos female header - Pins 2-7
· NOTE:· Pins 0 and 1 are isolated on the left edge of the board to
··········· provide clearance for an XBEE or other serial device.
4-pin R/A header·for PropPlug programming
Reset button
The Expresspcb layout is attached.· This is a bare board, but any part numbers needed can be supplied.· Potential buyers must approve the layout.· If you are interested please PM me.
Sid
Sid Weaver
Don't have VGA?
Newzed@aol.com
Size· 3.8 x 2.5
5V and 3V regulator
DIP Prop
Reset button
Sid
Sid Weaver
Don't have VGA?
Newzed@aol.com
Sid
Sid Weaver
Don't have VGA?
Newzed@aol.com
