Larger LCD Screen with the propellor?
how well would a larger, say 7 inch screen work with the propellor? I assume you would have to boost the RAM a bit. Does anybody know of a good LCD Screen this size? Built in Speakers would be even better.
ACfishing
ACfishing
·Somebody said...
-Never Underestimate the power of human stupidity.
I have a 9" monitor TV/VGA input, only TV works with the prop, not sure why VGA does not, maybe because it is 800x480?
I'm probably going to buy a dual monitor in car DVD, it gets me two 7" screens for the price of two 2.5" screens. I need to check they have normal AV inputs first though or at least try them and send them back if not.
Graham
·· The physical size of the display doesn’t necessarily affect the memory requirements required to drive it.· In the case of video displays it is irrelevant.· The resolution of a VGA display will affect the memory requirements if you’re trying to use higher resolutions, but that doesn’t mean you have to.· I hope this helps.· Take care.
Ripped the screen out of the case and it's PERFECT. The screen has a nice plastic frame/case around it which holds the board on the back and looks/works great..
Can post the item # because it say that this page is no longer there
·Can you give me·the price of it
Thanks for any help that you can give me
.......ADDED I found the page Thanks........
Sam······
Post Edited (sam_sam_sam) : 12/3/2006 1:40:44 AM GMT
Try searching for B000J4FQW4 on the target site.
Jim C
It takes VGA or AV(TV) so would be good for development. There seem to be lots of these on ebay, they are designed for "carputers".
and the detailed info is --- Catalog # : 10417762 ASIN: B000J4FQW4 DPCI: 008-10-0211
As you can see the screen moduled is quite self contained, the connections are video, 9v DC, 5v DC, brightness and colour. I may just set brightness and colour with fixed resistors rather than pots, not decided yet.
Thanks Sharpie for the inspiration to actually try.
Graham
Remember, all LCD monitors are not created equal!
Before you modify any display, test it first! Also make sure you can return it easily, if you don't like the way it looks!
The first 5.6" monitor I bought at Fry's Electronics several years ago ($80), always thought it had a crappy video display, but displays tv_text.spin very clearly. So I bought a cheapey off of ebay, about $54 delivered. As seen from the photo it can't display tv_text.spin as clear as the older one.
www.target.com/gp/detail.html/sr=1-2/qid=1165073004/ref=sr_1_2/601-2872463-5133701?ie=UTF8&asin=B000I5IYAA
Ed
ACfishing
Where did you get the screens from? I'm also in the UK and could use a couple of small screens for my projects.
Another option, if you can find one, is the old Playstation Portable screen. Its a 5" screen with built in speakers and can accept composite video, or VGA with a little bit of hacking. They're pretty cheap too.
Hope that helps
Mark
You might want to wait until I get one up and running in its new format before buying, they are exculded from the 16 day guarentee, presumably because people bought them, went on holiday with them and then took them back.
Graham
Here in Melbourne Down under OZ you can buy a neat 34CM TV from the Aldi stores for $89.00
Should work well with the Propeller ...... http://www.aldi.com.au/
Built in sound as well
In US dollars that would be about $60.00 and in GBP probably about $35.00
I reckon great value Going to get one tomorrow for sure..to test it
Ronald Nollet Parallax Australia distributor
The 9v connections is a little strange to me on a 12v system, when I measure it I get 7v anyway. What are the chances that it will run on 12v OK? That would save a regulator.
The control inputs are:
colour: 2-3v range
Brightness: 1.6-2.6v range
GND
+5v
Widescreen: 0v=wide and 0.7v=normal Probably a transistor base drop?
on/off: This doesn't seem to change.
Graham
Any info appreciated.
Graham
Graham
Graham
Graham
