Cool Compass
I just got a compass, Hmb55, and I was wondering why is it that when i rotate the compass on a flat surface, and then back to it's orginal position I don't get the same reading I got intially??
Thanks for your help
SoulJaH
SoulJaH
Phil
Andy Lindsay
Education Department
Andy Lindsay
It's interesting to watch a Boe-Bot with a digital compass that's heading north take a +/- 60 degree detour, lining itself up with what I'm assuming is a pipe or rebar under the concrete foundation. It always does it in the same place on my office floor.
Aside from the big magnet mentioned earlier, I haven't ever seen one of those modules exhibit "memory" like that.
Andy Lindsay
Just out of curiosity, what is your system mounted to, i.e. what all moves when you rotate the HM55B? Also, are the raw readings symmetrical about zero when the compass is rotated by 180 degrees? If not, how much are they offset?
If I had to guess on the source of the problem, I'd be willing to wager that it's probably an external electro-magnetic source which is skewing the readings. An unnoticed relay, motor, solenoid, or any device that has a magnetic coil within it would do the trick.
That is really too large an error to be almost anything else.
Bruce Bates
<!--StartFragment -->
