using a boe-bot to control another boe-bot
is it possible to use one boe-bot kit to remotley control another using the included infra-red hardware?
i only need simple foreward, reverse, left, right, and maybe open/close for a single servo gripper.
so really, one BOE would be a hand held contoller with buttons on the breadboard and the other BOE would be a boe-bot.
Meaning, to generate a 1 mSec pulse, you do: FREQOUT IRPin, 1, 38000
To generate a 2 mSec pulse, you do: FREQOUT 2, 38000
To detect: PULSIN IRDetect, PulseVal
http://www.parallax.com/html_pages/resources/catapps/cat_toddance.asp
The majority of the book shows you how to build programs that use a universal remote to control a Boe-Bot.· Appendix B explains how to accomplish BS2-to-BS2 infrared communication, and Appendix C explains how to use another BS2 instead of a remote to·transmit infrared control signals, though the range is quite small compared to the universal remote (and tiny compared to RF).
http://www.parallax.com/detail.asp?product_id=28139
If the dancing Toddlers inspire you·to try the RF route, Andy has posted an example·project using a second BOE, RF modules and an accelerometer.· "Tilt Radio Controller for your Boe-Bot" is linked in the Stamps in Class Mini-Projects sticky-thread, under "Boe-Bot + Accelerometer" :
http://forums.parallax.com/showthread.php?p=560570
An inexpensive second BS2 platform is the BASIC Stamp Activity Kit, which has a HomeWork Board:
http://www.parallax.com/detail.asp?product_id=90005
This should give you some ideas to start with!
Stephanie Lindsay
Editor, Parallax Inc.
Post Edited (Steph Lindsay (Parallax)) : 11/29/2006 12:43:14 AM GMT
SimpleIrTransmit.bs2 can be loaded into a Boe-Bot with pushbuttons connected to P3 and P4 (like in What's a Microcontroller, Chapter 3, Activity #4) and an IR LED with a 220 ohm resistor in series connected to P8.·
SimpleIrReceive.bs2 can be loaded into a Boe-Bot with the IR detection circuits from Robotics with the Boe-Bot, chapters 7 and 8.· The only circuit that actually gets used is the IR receiver connected to P9.
Point the transmitter board's IR LED at the receiver board's IR receiver that's connected to P9 and press and hold both Buttons.· (You'll need to keep the IR LED in close proximity and line of sight to the IR receiver while you're driving.)· The receiver Boe-Bot should go full speed forward.· If just the P4 pushbutton is pressed and held, the Boe-Bot will rotate left.· If just the P3 pushbutton is pressed, the Boe-Bot will rotate right.· If no pushbuttons are pressed, the Boe-Bot should stay still.
So, is this more what you had in mind?
Andy Lindsay
Education Department
is it possible to use more than 2 buttons though?
also, range isnt a big deal, i have a cool all-directional attachment dealie for the IR reciever, and i'll probobly build an IR blaster for the transmitter.
also, i already have a bunch of code written to do what i want, but it was designed around having the bot tethered, do you think it would be possible to modify that to work with IR?
Post Edited (HavoKane) : 11/30/2006 4:08:43 AM GMT
