hex convertion
i need to convert a·3 byte hexadecimal number into the corresponding decimal value. As i just have to print this number (in decimal), the result (that is larger than a word) may be stored as separate ascii-bytes in memory.
e.g. "FC 15 DC" (=16520668 decimal) should become in memory:31h 36h 35h 32h 30h 36h 36h 38h·Can somebody help me how to do it? or even better: has someone a piece of code to do so?
Set up a loop to add 6-5-5-3-6 to those 5 bytes as many times as the third bytes value
For example 01 FF FF
65535
+65536
131071
Each column added separately carrying the overflow to the next byte, (long hand addition) (store the overflow in a separate byte variable)
So in the first run through the loop you add 5+6=11, carry the 1 over and store 1 in the memory location
Then you add 3+3+1 and store 9 in next byte to the left
column3 from the right is 5+5 so you store 0 and carry the 1 again
Same thing as longhand addition only the computer logic is doing it.
Final result will be the 8 byte array has the real number values for each place, then add 48 to each location to convert to ascii
Done.
Think Inside the box first and if that doesn't work..
Re-arrange what's inside the box then...
Think outside the BOX!
When I began my higher education career, I used to teach the stuff you just wrote about. Today, I am a college dean and the CIO and about to retire.
I could not have done better. On my best day, I might have done as well.
--Bill
You are what you write.
' {$STAMP BS2}
' {$PBASIC 2.5}
'four words hold the Hex number
outstring VAR Byte(10)
inHex VAR Word(4)
idx VAR Byte
borrow VAR Word
Main:
DEBUG HOME, "$FC15DC converted to ASCII",CR
'breakup number into bytes· - example $FC15DC
inHex(0)=$00:inHex(1)=$FC:inHex(2)=$15:inhex(3)=$DC ' Load them as byte into scratch words
'the magic happens here
FOR idx=9 TO 0
· borrow = inHex(0)//10 * 256
· inHex(0) = inHex(0) / 10
· inHex(1) = inHex(1) + borrow
· borrow = inHex(1)//10 * 256
· inHex(1) = inHex(1) / 10
· inHex(2) = inHex(2) + borrow
· borrow = inHex(2)//10 * 256
· inHex(2) = inHex(2) / 10
· inHex(3) = inHex(3) + borrow
· outstring(idx) = inHex(3)//10 + 48 'add ASCII Zeros
· inHex(3) = inHex(3) / 10
NEXT
DEBUG· STR outstring\10,CR
END
Have Fun
TR
Post Edited (TechnoRobbo) : 11/29/2006 4:41:32 AM GMT
1)··A technical question.
2)· An amazing mathematical answer.
3)· A compliment from someone who understands the question and answer.
4)· Someone to write the code to solve the problem.
If I owned a company I'd hire all 4 of you to do something.
Post Edited (terahertz) : 11/29/2006 4:39:23 AM GMT
My worst nightmare is to memorize the winning ticket then not be able to find it, where the heck did I put that 20 million dollar winning ticket anyway...
Will you be offering a Dental plan? 'cause it's all about the benies.
Have Fun
TR
Dijan
