agfa
Post Edited (agfa) : 2/13/2007 2:33:24 PM GMT
- Stephen
PAR
You should be able to correct this by changing the pulse value for one of the servos (that is, run one at 650 and the other at 849 and see if you see a difference... if not, try 650, 848, then 650, 847, etc. until it tracks straight)
check your mounting as well... are both servos securely mounted to the boebot?· are the wheels on straight and secure?· Is the frame bent?
Upgrading to a BS2-SX will probably allow your code to execute at a sufficiently fast rate to overcome any code anomalies, or inefficiencies.
The frame being out of true could be the entire problem in a nut shell. One wheel is experiencing more rolling friction than the other is. The only cure here is to address the source of the problem, as it may not remain consistant, or constant and thus is not easily software correctable.
Bruce Bates
Post Edited (Bruce Bates) : 11/27/2006 9:00:02 AM GMT
