Sensor question
Hi everone,
i build the circuit (in the manual where the sensor part). the circuit is correctly working, however, the IR sensor does not work the way that i wanted. i need to point the sensor upward to the celling. by doing this, it some time work. if i put the IR sensor straight as shown in the manual, it won't work at all. can you guy tell me how do i slove this problem.
thanks you
thanks you
- Stephen
