BS2sx Stamp Problem
Hi guys,
My BASIC stamp was working fine, but suddenly, my PC no longer detects it.
I get Loopback and Echo, but I cant identify or send anything to it.
The stamp runs fine with what is already programmed to it, but I desperately need to update something for a project.
I'm using serial connector and I have a 9V connector (not a battery) powering a breadboard (Parallax) and the microcontroller.
Please help...
Please help...
I disconnected everything and left only Vss/Vin for the power.
Still same problem [noparse]:([/noparse]
I have a 9V connector with a negative pole connecting to Vss
I have the positive pole connecting to Vin
·· Yes, but the BASIC Stamp has an on-board regulator and when you put voltage into Vin, 5V should appear on Vdd.· Did you measure the Vin?
11.2V (?) going into Vin
5V on Vdd
What I'm thinking is that somehow the program inside the stamp looped itself and it doesnt let me reprogram it.
Is that scenario possible?
Is there anyway to clear the memory on the board?
·· That scenario is not possible…The BASIC Stamp Editor resets the module prior to programming and initiates programming before your program could interfere.· Have you changed cables or computers or are you now using a USB adapter?· Is this a laptop or desktop computer?· On a breadboard there is more of a chance of something going wrong than on a development board.· Is it possible you connected something wrong even briefly?
The breadboard has nothing on it except the stamp module and 2 wires from +/- to slots that lead to Vin/Vss
Thanks for your interest in this problem, I appreciate it [noparse]:)[/noparse]
