propellor programmer
I am thinking about buying the prop chip but I am a little low a cash so I am trying to figure out the cheapest way to get going with it. I was hoping to find a schematic to a homebrew adapter but so far I haven't been able to find one on these forums but hopefully I have overlooked it. So if anyone knows maybe you could be kind enough to post a link to it.
thanks
Post Edited (Vertex78) : 11/25/2006 2:05:11 PM GMT
thanks
<http://www.wulfden.org/PRC/index.shtml>
...although it would require you to assemble it. I used the rs232 interface shown on the Propstick schematic for a programmer interface that also will do full duplex. It may be possible to sample the max3232 part.
Best, vatic
If you search posts in the APRIL/MAY 2006 timespan, you'll find a lot of info. This is when we were all still brewing boards. Mine ended up costing me less than the DEMO board. But, I think the education kit is probably the most effecient way to go, unless you have parts laying around. If you do, then grab a schematic and start soldering! I still exclusively use my homebrew board with complete success. You can see it at my personal gallery
One big post about them is:
http://forums.parallax.com/showthread.php?p=579595 This one is a good one.
http://forums.parallax.com/showthread.php?p=585142
http://forums.parallax.com/showthread.php?p=585449
http://forums.parallax.com/showthread.php?p=582077
http://forums.parallax.com/showthread.php?p=581759
http://forums.parallax.com/showthread.php?p=581907
http://forums.parallax.com/showthread.php?p=585091 This one is a good one.
That might be too much, but it should get you started. A few links might be useless to you...
-Parsko
http://forums.parallax.com/attachment.php?attachmentid=41153
then it will be able to do everything I need to program the propellor, right?
Also will this wirewrap socket fit the propellor chip?
[*]Sleeve material: brass [*]Lead length: .515" [*]Body height: .115" [*]Tin plated leads [*]Pins: 40 [*]Width: 0.6"
https://www.jameco.com/webapp/wcs/stores/servlet/ProductDisplay?langId=-1&storeId=10001&catalogId=10001&productId=94502
Post Edited (Vertex78) : 11/26/2006 2:51:09 PM GMT
With this.
Plus a 3.3 power supply.
Regards.
Alberto.
·Nice
Is the Header at the end of the board for all of the Propellor I/O pins and is there any thing else on the header
These Guys are having to much fun·
Sam
