Electronic Component References?
Does anybody know of a good print or online component reference that lists components by typical circuit usage?
So, for instance, if I was looking for diodes for designing a power supply, under the "diodes" category, I would look up "power supply" or "rectifier", and it would list common diodes for this application.
Thanks.
Thanks.
http://library.thinkquest.org/16497/home/index.html
The best way to specify parts, unfortunately, is to understand the math behind the specs.
[noparse][[/noparse]though they can be classified 'secret', etc.]. What ever is public is ours.
www.ziannet.com/NMAMARS/downloads//neets.htm
Or just Google NEETS
"If you want more fiber, eat the package.· Not enough?· Eat the manual."········
For those just looking for basic instruction, go here:
www.tpub.com/neets/book1/chapter1/index.htm
More stuff here:
www.tpub.com/content/neets/
- - - PLJack - - -
Perfection in design is not achieved when there is nothing left to add.
It is achieved when there is nothing left to take away.
Post Edited (PLJack) : 11/29/2006 9:47:34 PM GMT
If I look at the datasheet for a 2N2222 NPN transistor, it lists linear amplification & switching as suggested applications. However, with 100s or 1000s of transistors on the market, there should be a better way of finding the right one than guessing which datasheets to look at. So it would be great to look up "Linear Amplification" as the main category, then drill down to more specific characteristics from there.
Like those things you find in Wal-Mart for choosing which air filter model to use for your car...
http://www.findchips.com/
