Needing to seal a project box — Parallax Forums
DigitalDjDigitalDj Posts: 207
edited 2006-11-25 09:37 in General Discussion
Hello,
I need to seal a project box from the weather and wondered if anyone could tell me what is the best to use. I heard that silicon will· cause solder connections etc. to·corrode!
Please Help!
Kevin
Education And Experience Teaches Knowledge Not Arrogance ! (Unknown)
The Only Stupid Question Is The One Not Asked ! (Unknown, of coarse this is something that i would say)
Do Not Burn The Bridge That Has Brought You Forth You May·Need To Journey Back ! (Chinese)
  • James LongJames Long Posts: 1,181
    edited 2006-11-25 00:43
    There are clear versions of silicon that will not. It depends on the catalyst that is used. I can't remember off hand which catalyst can be used.
    James L
    edited 2006-11-25 01:14
    If it smells like vinegar (acetic acid), it's the wrong kind. BoatLife has some "odor free" silicone sealants that I've used successfully around electrical work. Read the label...
  • DigitalDjDigitalDj Posts: 207
    edited 2006-11-25 03:11
    Got exactly what i needed at lowes and even got it in the color i wanted!
    Kevin
    edited 2006-11-25 04:11
    Thanks Phil....it has been a while.
    James L
    Silicon usually uses CN ion or cyanide to catalyze. That is why they make a non-toxic version for fish tanks.
    You could always use an adhesive tape to seal the box after assembly.
    "If you want more fiber, eat the package.· Not enough?· Eat the manual."········
    ···················· Tropical regards,····· G. Herzog [noparse][[/noparse]·黃鶴 ]·in Taiwan
