RGB LED SX/B Example
This is something I have been wanting to do for some time now. Mixing colors with an RGB LED.
So lets start at the beginning, The object is to vary the color of each red, green and blue LED to produce a different color. You can think of it as a standard 8 bit color palette.
So lets say you wanted to produce the color purple. That would be full red, full blue and no green. Easy enough. But what if you wanted to produce a dark purple. This can be done by reducing the intensity of the blue LED.
But how?
The answer is in PWM (pulse width modulation).
If you are new to PWM, then lets get one thing straight. You DO NOT control the color of an LED by blinking it at different speeds. Blinking is a byproduct of PWM. Controlling the color is a function of reducing the voltage that the LED sees. By reducing the voltage, you decrease the brightness.
I will provide two examples. One I will just type at the end of this paragraph, the other is an attached file that will also be pasted to the end of this post.
A simple example.
The Red LED is connected to RB.0. Green connected to RB.1 and Blue connected to RB.2.
Place the OUTPUT and PWM commands below into your SX/B Template:
Start:
' initialization code here
OUTPUT RB.0
OUTPUT RB.1
OUTPUT RB.2
Main:
pwm RB.0, 255, 1
pwm RB.1, 0, 1
pwm RB.2, 255, 1
GOTO Main
Please note that the color intensity comes from changing the DUTY cycle, not the duration.
To create a dark purple you would set RB.2 (blue) to something like 180.
There are a couple issues with the above approach. The first is that the duration of the PWM is too long. This destroys the POV (persistence of vision) effect. You can see this by looking at the LED and the quickly look up, or down or anywhere for that matter. You will see red, green and blue streaks coming from the LED. Very distracting to say the least. Bump up the duration from 1 to 5 to see the full effect.
Another issue is that you are applying PWM to each LED one after the other. In other words the above code takes 3 milliseconds to PWM all three LEDs. You really need to PWM all three at the same time.
The final issue is that pausing at a certain color is very problematic with the above method.
The sample code provided solves all these issues. The code is pretty heavily commented so I will not reproduce it here.
Basically it uses an INTERRUPT and some helper functions to produce some really pleasing results.
Enjoy and have some fun this weekend.
A more advanced method:
- - - PLJack - - -
Perfection in design is not achieved when there is nothing left to add.
It is achieved when there is nothing left to take away.
Post Edited (PLJack) : 11/24/2006 9:09:35 PM GMT
But how?
A simple example.
Start:
OUTPUT RB.0
OUTPUT RB.1
OUTPUT RB.2
Main:
pwm RB.0, 255, 1
pwm RB.1, 0, 1
pwm RB.2, 255, 1
GOTO Main
' Purpose... RBG LED Example
' Author.... PLJack
' E-mail.... kellylabs@fastmail.fm
' Program Description:
'--- Don't Forget: Zero is full brightness and 255 is off.
'--- This example demonstrates the mixing of colors
'--- using a RGB LED.
'--- CAUTION: Be careful with bright LEDs while using
'--- this code, staring at a bright LED for most of
'--- the day can have undesirable results for your
'--- eyes.
'--- I find that surface mount LEDs work best for
'--- color mixing. Most 5mm LEDs seem to have the
'--- three LEDs too far apart for proper convergence
'--- (mixing).
'--- General:
'--- Basically there are several components to this
'--- example. The first is an INTERRUPT that is
'--- constantly monitoring the PWM lines for RGB.
'--- There are three variables for the LED, RedVal,
'--- GreenVal and BlueVal. You can change these
'--- variables at any time. The interrupt will
'--- automatically change the LED to the new value.
'--- Because we are using an interrupt you can use the
'--- PAUSE command and the LED will continue to emit
'--- light. This makes it very easy to display a color
'--- for a certain amount of time.
'--- Operation:
'--- Not much to it really. There are three main
'--- functions for you to use.
'--- Diag:
'--- Used at startup. It will display the red, green
'--- and blue LEDs in that order. This is useful to
'--- determine that your LED is correctly connected to
'--- the SX.
'--- TransitColor [noparse][[/noparse]Num]:
'--- This function creates a random color. Then makes
'--- a transition from the current LED color over to
'--- the new color. It performs this transition in
'--- 255 steps. You can provide and optional parameter
'--- to pause for [noparse][[/noparse]Num]
'--- milliseconds per step.
'--- The max transition time is 255 steps X 255ms = 65
'--- seconds.
'--- RandomPulse [noparse][[/noparse]Num]:
'--- This function actually creates some beautiful
'--- results. It turns off the LED, creates a random
'--- color then slowly raises the led to full
'--- brightness and finally fades to off.
'--- The great results come from the fact that it
'--- increments the RGB colors by one. So if the color
'--- has a lot of blue in it (strongest color) as it
'--- fades blue will be the last led to fade. Thus
'--- mixing with the red and green as those colors are
'--- reduced.
'--- This also has an optional parameter to pause for
'--- [noparse][[/noparse]Num] milliseconds per step. Although the total
'--- number of steps is unknown. It depends on the
'--- value of the strongest color.
'--- And remember to have fun.
'--- Please forgive my breaking of the Uppercase keyword convention.
'--- After years of coding in PC languages, I just can't take
'--- all those uppercase words.
' Device Settings
DEVICE SX28, OSC4MHZ, TURBO, STACKX, OPTIONX
FREQ 4_000_000
ID "SXB 1.50"
' IO Pins
RedLED var RB.0
GreenLED var RB.1
BlueLED var RB.2
' Constants
'--- LED TYPE
'--- Common anode - SX pins sink to ground.
'--- Common Cathode - SX pins source the voltage.
'--- Un-comment the correct type for your LED.
'--- Common Anode
'LEDOn con 0
'LEDOff con 1
'--- Common Cathode
LEDOn con 1
LEDOff con 0
'--- Color Clip
'--- If your LED has a color that is over powering the others you can
'--- clip its brightness here. Keep in mind this is not a global clip
'--- because the color reduction is not proportional to the others.
'--- But it will prevent a color from becoming too bright.
'--- Zero is full strength. Increase number to reduce total brightness.
'--- To do this properly you would need a variable resistor
'--- on each LED. Run them at full brightness, then adjust
'--- each VR for a perfect white.
'--- You might have some luck performing a proportional adjust on
'--- the fly via code, but I think rounding errors might cause more
'--- trouble than it is worth.
C_RedClip con 0
C_GreenClip con 0
C_BlueClip con 0
'--- Defaults if no parameter is provided
C_DefaultTransitSpeed con 5
C_DefaultPulseSpeed con 15
'--- Just substitutes for 0 and 255 incase you should
'--- ever want to change them.
C_PwmMin con 0
C_PwmMax con 255
' Variables
'--- This is the value (duty cycle) given to each LED at each INTERRUPT.
RedVal var Byte
GreenVal var Byte
BlueVal var Byte
'--- Sometimes handy to store the above variables.
RedValCopy var Byte
GreenValCopy var Byte
BlueValCopy var Byte
'--- Used for the duty cycle inside the INTERRUPT.
RpwmCounter var Byte
GpwmCounter var Byte
BpwmCounter var Byte
'--- For use constructing loops.
LoopIdx var Byte
'--- Used to increase the time a loop takes to finish.
FadeSpeed var Byte
'--- For functions that return a Byte variable.
ReturnVar var Byte
'--- Always nice to have a few around. Always assume as volatile.
UtilVar1 var Byte
UtilVar2 var Byte
UtilVar3 var Byte
INTERRUPT 30000
ISR_Start:
'--- Add one to pwm counters.
'--- Note they will roll over to zero after 255.
Inc RpwmCounter
Inc GpwmCounter
Inc BpwmCounter
'--- Red LED PWM
if RpwmCounter > RedVal then
RedLED = LEDOn
else
RedLED = LEDOff
endif
'--- Green LED PWM
if GpwmCounter > GreenVal then
GreenLED = LEDOn
else
GreenLED = LEDOff
endif
'--- Blue LED PWM
if BpwmCounter > BlueVal then
BlueLED = LEDOn
else
BlueLED = LEDOff
endif
ISR_Exit:
RETURNINT
PROGRAM Start
' Subroutine Declarations
TransitColor sub 0, 1
RandomPulse sub 0, 1
Diag sub 0
SeedVars sub 0
RandomColor sub 0
RandomUtilVar sub 0
RaiseStrongest sub 1
FadeStrongest sub 1
StoreColor sub 0
RestoreColor sub 0
GetStrongestColor sub 0
' Program Code
Start:
'--- Set LEDs as outputs.
OUTPUT RedLED
OUTPUT GreenLED
OUTPUT BlueLED
'--- Un-comment to perform a quick diagnostic at start up.
Diag
'Seed anything that the RANDOM command will use.
SeedVars
Main:
TransitColor
' RandomPulse
Goto Main
' Subroutine Code
RandomPulse:
'--- Too few parameters, set to default.
if __PARAMCNT <> 1 then
FadeSpeed = C_DefaultPulseSpeed
else
FadeSpeed = __PARAM1
endif
RandomColor
'--- Bring color to full brightness.
RaiseStrongest FadeSpeed
'--- Now fade until off.
FadeStrongest FadeSpeed
return
TransitColor:
FadeSpeed = C_DefaultTransitSpeed
else
endif
'--- Create a random color, only with the util vars this time.
RandomUtilVar
'--- Now bring the current LED values towards the new values.
for loopIdx = C_PwmMin to C_PwmMax
if RedVal <> UtilVar1 then
if RedVal < UtilVar1 then
inc RedVal
else
dec RedVal
endif
endif
if GreenVal <> UtilVar2 then
if GreenVal < UtilVar2 then
inc GreenVal
else
dec GreenVal
endif
endif
if BlueVal <> UtilVar3 then
if BlueVal < UtilVar3 then
inc BlueVal
else
dec BlueVal
endif
endif
pause FadeSpeed
next
return
FadeStrongest:
StoreColor
UtilVar1 = GetStrongestColor
'--- Find number of loops required to turn off color
UtilVar2 = C_PwmMax - UtilVar1
'--- Bring down all colors.
for loopIdx = C_PwmMin to UtilVar2
if RedVal < C_PwmMax then
inc RedVal
endif
if GreenVal < C_PwmMax then
inc GreenVal
endif
if BlueVal < C_PwmMax then
inc BlueVal
endif
pause FadeSpeed
next
RestoreColor
return
RaiseStrongest:
StoreColor
'--- Set LEDs to off.
RedVal = C_PwmMax
GreenVal = C_PwmMax
BlueVal = C_PwmMax
'--- Bring up all colors.
if RedVal > RedValCopy then
dec RedVal
endif
if GreenVal > GreenValCopy then
dec GreenVal
endif
if BlueVal > BlueValCopy then
dec BlueVal
endif
pause FadeSpeed
next
RestoreColor
return
StoreColor:
RedValCopy = RedVal
GreenValCopy = GreenVal
BlueValCopy = BlueVal
return
RestoreColor:
RedVal = RedValCopy
GreenVal = GreenValCopy
BlueVal = BlueValCopy
return
RandomColor:
random RedVal
random GreenVal
random BlueVal
'--- If a color clip is set, honor it.
if RedVal < C_RedClip then
RedVal = C_RedClip
endif
if GreenVal < C_GreenClip then
GreenVal = C_GreenClip
endif
if BlueVal < C_BlueClip then
BlueVal = C_BlueClip
endif
return
RandomUtilVar:
'--- This is a bit of an odd ball function.
'--- To perform the transition for the TransitColor function
'--- we need a few random numbers. Here we just use the UtilVars
'--- instead of wasting RAM for three one off variables.
random UtilVar1
random UtilVAr2
random UtilVar3
if UtilVar1 < C_RedClip then
UtilVar1 = C_RedClip
endif
if UtilVar2 < C_GreenClip then
UtilVar2 = C_GreenClip
endif
if UtilVar3 < C_BlueClip then
UtilVar3 = C_BlueClip
endif
return
GetStrongestColor:
'--- Assign strongest (low val) color to ReturnVal.
if RedVal < GreenVal then
ReturnVar = RedVal
else
ReturnVar = GreenVal
endif
if ReturnVar > BlueVal then
ReturnVar = BlueVal
endif
return ReturnVar
SeedVars:
RedVal = 50
GreenVal = 100
BlueVal = 150
UtilVar1 = 150
UtilVar2 = 100
UtilVar3 = 50
return
Diag:
'--- A simple diagnostic to confirm that the LED is
'--- connected to the SX correctly and is working properly.
RedVal = C_PwmMax
GreenVal = C_PwmMax
BlueVal = C_PwmMax
RedVal = C_PwmMin
Pause 500
RedVal = C_PwmMax
GreenVal = C_PwmMin
Pause 500
GreenVal = C_PwmMax
BlueVal = C_PwmMin
Pause 500
BlueVal = C_PwmMax
RedVal = LoopIdx
pause 2
next
GreenVal = LoopIdx
pause 2
next
BlueVal = LoopIdx
pause 2
next
RedVal = LoopIdx
BlueVal = LoopIdx
GreenVal = LoopIdx
pause 4
next
return
' User Data
Pgm_ID:
DATA "SX/B RGB LED Example", 0
- - - PLJack - - -
SXB
13K
Very nice.
Just a couple notes though:
· You only need 1 PWMCounter because all three will always be the same value anyway.
· Check the assembly listing, and if it doesn't use any __PARAMx variables, then add NOPRESERVE to the INTERRUPT line. That will save a bunch of cycles in the interrupt.
· 30000 interrupts per second is a refresh rate of 117Hz. 60Hz is plenty fast, which would be 15360.
· I would add the second parameter to FREQ (to account for time spent in the interrupt).·You can use SX-Sim·to see how many clocks are spent in the interrupt.
When you are ready for a challenge, make the interrupt routine adjust the brightness (like your TransitColor routine does).
Bean.
Stuff I'm selling on ebay http://search.ebay.com/_W0QQsassZhittconsultingQQhtZ-1
"People who are willing to trade their freedom for·security deserve neither and will lose both." Benjamin Franklin
Post Edited (Bean (Hitt Consulting)) : 11/25/2006 12:21:38 AM GMT
Yes there are optimizations that can be had, wanted to make it more of an example.
Got me on the PWMCounter though. Doh!
I found 30000 gave the best results. I meant to get back to that number, forgot.
Thanks for the feedback.
- - - PLJack - - -
I hope you still remember this project after 2.5 years.
I worked on it last night and enjoyed it. Need to experiment more on the different options on PAUSES.
On a simpler note, can you give some guidelines if I just want to simply do the following:
A fade time (preferably with speed adjust) and a scene time (LEDOn for a certain amount of time via a PAUSE) for each color where I can control the time for each fade time and scene time.
Also a transistion time where one LED fades out and the next LED fades in so that there is no complete blackout at transition but a slight mixing of the two interacting colors.
Thanks.
Danny
2 1/2 years! Holy C##P.
I'm really happy you enjoyed it. That's exactly why I wrote it.
Actually I remember this article well.
I just re-read it. Pretty rough code.
Since then I have done allot of RGB code. I've made night lights, counter lights.
Currently I have a white globe attached to the wall that pulses different colors depending on what is in my email inbox.
If you don't mind being patient I will fire up the SX computer and see what I have for code that can help.
Patient being the key word there. Could take a handful of days.
BTW, I did another write up on RGB color in these forums here:
Link: RGB Color Models
BTW again, although I have not logged into the forums in a long time I still read them a few times a week.
Hi Guys!
- - - PLJack - - -
Post Edited (PLJack) : 3/27/2009 11:41:36 PM GMT
Good to hear from you. You've not post anything but looks like you''ve been busy working other projects.
I have gone through your older posts as well.
I will patiently wait.
Thanks.
Danny
There are ways to create the presence of black, I use white plastic and while other leds are on that one spot is not is of coarse the absence of light and looks dark. This also works for gray scales. The other way is using smoked black acylic the same as what they use for non glare applications. This also improves the richiness of colors and allows·intensities of white light to create gray.
Kevin
