how do i make sure sx key is still functioning? — Parallax Forums
KelvinLKelvinL Posts: 15
edited 2006-11-27 22:31 in General Discussion
Hi there
I get SX/B notice me that SX key can't be found in·COM port after few times of code writing.
Then SX key never work up anymore, how do I make sure SX key is funciton or dead?
and I also found·a problem that same code running in debug mode and run mode has different result:
· the byte value is different when sending out to RS-232. (the result running under debug mode is correct, but not in full run mode)
·Dose this happen? Or may I done things wrong?
I am·shifting from using BS2 to SX, anything I should notice?
Thanks.
  • BeanBean Posts: 8,129
    edited 2006-11-25 00:03
    Kelvin,
    Make sure you power supply is not dipping below 5.0 volts when the SX-Key start up.
    If you are using the OSC4MHZ setting on the device line, then serial communication will not work correctly because the internal oscillator is only +/- 8% accurate. It WILL work when debugging because when you are debugging the SX-Key supplies the clock and the SX-Key is very accurate.
    Bean.
    Stuff I'm selling on ebay http://search.ebay.com/_W0QQsassZhittconsultingQQhtZ-1
    "People who are willing to trade their freedom for·security deserve neither and will lose both." Benjamin Franklin
  • KelvinLKelvinL Posts: 15
    edited 2006-11-25 02:25
    Many thanks, Bean~
    It really reacts as you said.
    Later on I added an external 20MHz crystal to it,
    but SX run in a unconstant pace, and even go to a stop (i toggled an LED to monitor it).
    Do i miss anything?
    Here is what i set to clock directives
    DEVICE SX28, OSCXT2, TURBO, STACKX, OPTIONX
    FREQ 20_000_000
    Kelvin Liao
    edited 2006-11-25 04:09
    Hmmm,
    Can you post your code ?
    Also do you have a 10K resistor on /MCLR to Vdd ?
    Bean.
    edited 2006-11-25 04:57
    Hi Bean,
    I do attach a 10k resistor on /MCLR to vdd.
    The purpose of my code is to send data to a COM port by routing through MAX232 driver.
    The same code is doing by BS2 very well, and doing correctly on SX debug mode.
    Here is code below, sending out characters a~z via Max 232, it's just a test.
    Start:
    tris_a.0=1
    tris_a.1=0
    tris_a.2=1
    tris_a.3=1
    i VAR Byte
    char VAR Byte (1)
    i=0
    inchar(0)=0
    Main:
    char(0)=i+"a"
    SEROUT RA.1 ,T2400,char(0)
    PAUSE 200
    toggle rb.0
    i=i+1
    i = i // 26
    GOTO Main
    Kelvin Liao
    edited 2006-11-25 14:51
    Kelvin,
    The VAR lines should be done before the code.
    "TRIS_A.0 = 1" is not valid. Use "INPUT" or "OUPUT".
    I assume "inchar(0) =0" should be "char(0) = 0"
    Try this:
    FREQ 20_000_000
    i VAR Byte
    char VAR Byte (1)
    PROGRAM Start
    Start:
    OUTPUT RA.0
    OUTPUT RA.1
    INPUT RA.2
    INPUT RA.3
    i=0
    char(0)=0
    Main:
    char(0)=i+"a"
    PAUSE 200
    toggle rb.0
    i=i+1
    i = i // 26
    GOTO Main
    Hi bean,
    Thanks again,
    As you said doing "tris_a.0=1" is invalid, I wonder if you are telling me that doing so won't take any effect on INPUT/OUTPUT register,
    Or, this command is obsoleted and being replaced by INPUT command?
    The command seems correct syntactically.
    Kelvin Liao
