Java 7-Segment LED dislay value creator
this program was created by me because i was tired of hand drawing 7 seg LED displays so i could get the little 8 bit bin number, so i threw some code together so i could stop with the drawings. this is fairly self explanatory just click the segments you want lit up and click "convert" then to reset the display click "reset". the little value feild has the bin number to use in you code. the numbers on the button represent bits 1-8 with button 1 = bit 8 , button 2 = bit 7, and so on
if you find any bugs or if you can think of an add on let me know!
P.S.: the file is a ZIP file it would not let me upload a ZIP file
-MM
-MM
lets see what this does... KA BOOM (note to self do not cross red and black)
