futaba servo — Parallax Forums
futaba servo
Johnny-5Johnny-5 Posts: 34
edited 2006-11-30 16:40 in General Discussion
do all futaba servos work the same? I was looking at some stronger servos from another site. Will they work with the pulsout command like the parallax ones?
  • Bruce BatesBruce Bates Posts: 3,045
    edited 2006-11-24 08:05
    Johnny -
    All analog servos should operate in the same manner, although the PUSEOUT values may have to be changed slightly.
    Bruce Bates
    <!--StartFragment -->
    edited 2006-11-24 15:54
    Guess what? Parallax sells custom made Futabas under its own brand name for the BoE bot.
    The Toddler uses generic Futabas.
    So how Futaba do you wanta be?
    "If you want more fiber, eat the package.· Not enough?· Eat the manual."········
    ···················· Tropical regards,····· G. Herzog [noparse][[/noparse]·黃鶴 ]·in Taiwan
  • AImanAIman Posts: 531
    edited 2006-11-28 14:47
    Not all Futaba's are created equal.
    Some are continous rotation and others won't go in a full circle. The strength of the servo changes depending on the application it is used for and the amount of power will vary the same way. My gas powered RC airplane using servos that move less then half a circle but my servo for robotics can go all the way around.
    Also, depenging on where they are hooked in and how makes a difference. For example my RC Airplane has the servos in the body with rods going to the wings which requires more force them my RC truck where the servos are geared straight to the steering.
    In answer to the PULSEOUT command - yes it will work with different servos provided current requirments are accounted for and handled correctly.
  • Johnny-5Johnny-5 Posts: 34
    edited 2006-11-30 08:27
    what about hitec servos? basically im looking for stronger servos... the ones that come with the boe-bot aren't real powerful, also can u get faster ones?
    The Hex Crawler we carry uses Hitec servos.· Almost every manufacturer of servos has high torque versions.· Some have metal gears and ball bearing shafts.
