stamp products with a pneumatic cylinder
Ok here goes. Has any one tried to use any stamp products with a pneumatic cylinder?
I can find a mini air pump and cylinders but the trick is the solenoid valves to allow me to control the cylinder to extend and retract under stamp control.
Does any one know of good supplier that handles them? I will probably be using 1/8 to 1/4 inch tubing so the PSI and volume of air will not be too high
I am trying to do this on a modest budget.
Take a look over here: http://www.herbach.com/
First key "neumatics" (sic) into the search engine. Check out the results. Next try "manifold". That will expose most, if not all, of the pneumatic gear they sell.
You will probably need a Darlington driver chip both because of the amperage, and due to the need for 24 VDC. Be careful, some of those units operate on 24 VAC!
Bruce Bates
<!--StartFragment -->
Also, look in your local yellow pages on "Pneumatics", "Fluid Power" and "Hydraulics".
Keep in mind that many of the local distributors may not care to deal with a "hobbiest", but if you can find one that doesn't mind, you would find a great wealth of information and support.
If you have a friend or relative in engineering or purchasing, you may also be able to get "in with" one of the local companies.
John R.
8 + 8 = 10
"If you want more fiber, eat the package.· Not enough?· Eat the manual."········
There is a place called hydraluic specilties out of Spring Lake Park MN that has a reasonable collection of both liquid and air actuators.
You can also look up scuba gear, Fish tank equipment, Semi equipment (air brakes etc) and simple hobby air compressors.
I have a very small air compressor that is about 1 1/2 gallons designed for hobby work. There are·a surprising amount of available valves and tools.
Steve
