Which would you prefer
Boe Bot tread or the crawler kit. Why?
I will be deploying to Iraq soon and I plan on taking my boe bot so I can work on it in between betting blown up. Just curious to know which would be better over there. I don't plan on taking it outside a controlled environment, but who knows.
On a much more important note is making sure you know that you have the full support from EVERYONE that particiaptes in these forums for protecting our country! It does not matter if we think the US forces "should" be in Iraq or not, that is not the point... the fact is that we support and give our greatest thanks to those that serve to protect us and our way of life... Our thoughts and prayers will be with you on your mission and look forward to your safe return!
I'm using the example code "roaming with ping" that came off this site. Does anybody have any ideas on how to compensate for the up and down motion? Maybe I'll get some time to figure it out in Iraq.
does that solve the problem? If so, then you have determined that it is an issue with the bot moving while the PING))) is trying to take a reading..
- run the 'bot around taking readings
- *if* a reading appears to be below your "escape/obstacle" threshold, THEN
- stop and take a reading while you are standing still.
- if you indeed have an obstacle while at rest, then avoid it, otherwise keep going.
Also, I often use two different thresholds -- one a "tuned" threshold to check for possible obstacles while "underway" and a separate threshold for checking obstacles while "still"
I agree with Mike that the time is not the issue, however bouncing around on different surfaces can make Sonar readings slide around quite a bit (in my experience, anyway). I've tried averaging, but the problem there is you don't necessarily get a quick enough reaction time -- it could take a number of cycles to bring your average low enough to trigger an escape routine. In a slow-moving Boe-bot that may not be such an issue, though.
