C++ to program a stamp? — Parallax Forums
Clay LClay L Posts: 18
edited 2006-11-23 16:53 in BASIC Stamp
I did a search but found nothing about using C++ rather than basic to program a stamp .
Is there any info on this subject?
Clay
  • Peter VerkaikPeter Verkaik Posts: 3,956
    edited 2006-11-23 00:42
    Basic stamps can only be programmed in Pbasic.
    You can take a look at the javelin stamp that
    is programmed in a subset of java, and that has
    a language syntax close to C++
    http://www.parallax.com/javelin/index.asp
    regards peter
  • Clay LClay L Posts: 18
    edited 2006-11-23 00:55
    Peter,
    Thanks for the reply! I will take a look at the javaline stamp.
    Clay
    edited 2006-11-23 15:49
    Well, I guess it would pay to read ll the documentation before posting stupid questions.
    I didn't realise the Stamp has an onboard Basic interpreter.
    For some reason I assumed compiled code was downloaded to it.
  • Brian CarpenterBrian Carpenter Posts: 728
    edited 2006-11-23 16:18
    Clay L, You might be interested in the SX family of micros that Parallax sells and supports. Currently, there is support for assembly and a very, very cool compiled code called SX/B. There is rumor, actually it was announced, that parallax will also be supporting a C compiler for the SX family. At less than $4.00 a chip, it might be the ticket.
    It's Only A Stupid Question If You Have Not Googled It First!!
    altitudeap
    Thanks for the reply.
    That might be something to look at after I get through playing with the Stamp. I received a Stamp kit as a gift and am looking forward to fooling around with it for a while.
    Clay
