need view on prop vs BS2
I am a hard core BS2 fan and I need to know how different the BS2 is from the propeller chip if some one could show me how hard it is to transition from one to the other.
thanks in advance
PS. if you could give me two examples one in basic and one in spin
thanks in advance
I'm a past Stamp2p user.·Spin is a steep learning curve at first. You must realize you are learning a new language. Also the transition to 8 cogs is a difference....that you have to be aware of. The passing of variables/values can be a difficult to comprehend.
The more you comprehend computer memory and accessing it seems to me(from my prospective)·will help a lot. I have to say....I don't understand these things well.....so I can only give my viewpoint.
I would say......it would be imperitive for you to buy a demo board....and play with it...if you think there is a remote possibility of needing it's resources.
If you are marginal with reguards to needing the propellers abilities......You may need to do some serious reading.
I believe that the propeller has great possibilities compared to any other micro out there. It is not impossible to learn Spin...but it takes more time than PBasic. Remember this is my opinion.
I know this is not exactly what you were looking for......but the best I can do at this time.
James L
Who says you have to have knowledge to use it?
I've killed a fly with my bare mind.
My experience so far with Propeller:
Yesterday - got my kit at 10am. Using basic examples (example#1 and Ping demo) with the Propeller Tool plus additional info here, I was able to get things running by 1pm. I assembled the Propeller Education kit (on GS PB-105 board) and interfaced it to the Ping sensor (5v), with output to my Seetron 4x20 LCD (5v, inverted TTL interface) I had handy. Had to create a new object for the Seetron display to make things work for the display, wasn't a problem. Time - 3 hours.
Today - Reviewed examples 1-16, didn't build anything, just read. Created first complete main program skeleton for my future robot project. Allocated Ping sensor to it's own cog, display updates to another cog, created 8 LED's to track active cog status, and allocated 6 remaining cogs random length tasks to give me a binking sequence of busy lights like the old 28 proc Sequent Balance system I always wanted to recreate. Cogs will each do more as I slowly build things up for the robot. Time - 2 hours.
Tomorrow - who knows. Have to figure out what hardware I want to use, but the Propeller has made the hardware interface a non-issue. Budget is the only limiting factor I can see slowing me down. If you've got a box full of parts for your BS2 projects and can do it with a BS2, I'd say you're set to be able to do whatever you want in only a few hours. Time - more than I'll count...
Spin was a lot to learn but it's very straightforward. It's was very satisfying going from pBASIC to Spin because although Spin is very different from pBASIC, there are things in Spin that I can point to and say "Parallax must have learned that trick from experience with the Basic Stamp." I can't think of anything I could do in pBASIC that I can't do in Spin with the same convenience. For instance, in pBASIC I can say "LOW 6" to bring pin 6 low. In Spin it is "OutA[noparse][[/noparse]6]~" to bring it low. The syntax looks stranger but the key idea is still the same - the language includes all the features that make your life easier.
So you don't lose anything going from pBASIC to Spin, and you gain a lot, especially objects.
Definitely either get the demo board, or get the PropStick USB and wire it up just like the demo board. That helps a lot. One difference between the Propeller and the Basic Stamp is that the Stamp is actually a serial port, eeprom, and microcontroller packaged together, while with the Propeller you have to provide an eeprom and programming interface. If you buy the demo board or the PropStick, then you get those included. And if you get the demo board, you get the keyboard and video jacks, etc.
Parallax is commited to support its past customers and the many schools that use the BasicStamp,
but the Propeller does everything better and more. And, it really is cheaper.
You can even get it reaching into radio wave transmission.
"If you want more fiber, eat the package.· Not enough?· Eat the manual."········
Prop takes a bit of getting used to, not about what it can do but trying to find something it cannot do.
Think of it as 8 faster SX stamps in one chip.
The Spin language itself feels similar to Pascal with a touch of C and Basic.
The software tools make it easy to read and help a lot.
Prop asm takes a bit to get used to, I feel.
Actually the more I work with Spin the less it seems like *any* other language I've ever tried. From whence does Spin derive? Most languages I know arose from someone taking 1 existing language and mixing in some things from 1 or 2 other languages. Spin on the other hand makes me go - whoa, where did that come from? But in a good way.
The experience of programming in Spin reminds me a lot of the experience of programming in Ruby, but not because the languages are similar, it's just that they're both very convenient to use.
