HYDRA: Game in the 128K card does not work
After having tried several demo games I tried the one that comes within the 128K card, the "Ball Buster".
To my surprise it does not work. Well it seems it is·doing something·but the picture is completely garbled!
It is interesting that every other demo I have tried work well except this one.
The led in the base of the card slot lights up, as expected.
If I compile the Ball Buster game in Propeller Tool and I load to RAM, it works. So the problem is not the game itself, but the card/slot.
Is there any special requirement/setting to work with games in the memory card ?
However, I have compiled and saved Ball Buster and it does not work !
If I try it again and again from time to time it success to work. This game even can fail when saved to RAM.
So, for some reason this game has trouble working on my Hydra.
Sounds like some bad bytes in the EEPROM.
"If you want more fiber, eat the package.· Not enough?· Eat the manual."········
Try downloading and programming·a program on the cart and see what happens.
Post Edited (JT Cook) : 11/22/2006 6:00:37 PM GMT
Also, as JT mentioned the drivers are the same for Ball Buster and many other game demos, so if one works they all work. Lastly, make sure that when you opened the game file, you didn't accidentally type a single character into it? Or a single space, that would change the whole program meaning. So try from the CD again, etc.
Sounds like the hardware is 100%, just you are getting a fragged file or using an old version. I just tried the production hydra with·the card with the game, uploaded, ran no problem. Runs on at least 50 different TV manufacturers and models here.
Does the racer 3D game work onm your TV, if so, same driver. Also, the same driver is used for alien invasion, give that one a try as well.
Andre'
Post Edited (AndreL) : 11/22/2006 6:35:16 PM GMT
Regarding BallBuster. Which is the difference between versions 1,2,3,4,5 ?
Its possible the eeprom on the memory card has a bad cell, but it would be the first time I have ever actually seen that. Atmel are very good chips and very reliable.
Andre'
I was trying to fix the problem with Tiny Basic so I removed the keyboard and the Ball Buster problem vanished!
I have replaced the keyboard with another one identical that I had from Parallax Demo Kit. Now it works as expected.
Thanks for your support.
