Not Enough Pins?
Jon Keinath
I am trying to connect a lot of different Integrated Circuits to a Javelin Stamp (it has the same # of I/O pins as the BS). I don't know if I am going to have enough pins to complete this task. I have attached a picture that shows the devices I am trying to connect, and I am looking for suggestions on how to connect all these devices. I have already shown some connections I plan on using. Is there any suggestions?
-Jon
-Jon
And you can hook up the serial lines for your LCD using a 74HC245 or similar chip.
(Also controlled by the 138 )
Don't visit my new website...
I will look into implementing them, and let you know how it turns out.
I was able to combine the CS Chips by adding a 74**595, but I had to separate the clock lines to the 595 and the MAX535 DAC.
-Jon
www.jonkeinath.com
I originally used a 10K resistor to protect the 74151 from having to source too much current (TTL doesn't like to source current) but found that with a 10K resistor it was not able to pull the LCD input low enough, so I changed it to 1K, which should still not cause damage to the 74151.
