Wire Splicing
I am using one wall wart to power 6 led circuits. I have 6 10' DC jack wires so 6 positive and 6 negative. I need to connect them to the positive and negative wires comming from the wall wart.
I am stripping the wires connecting them all and soldering then using shrink wrap to cover each 1 to 6 wires and then a larger shrink wrap to cover the 2from the wall wart and 12 wires out.
Is there a better way using a crimp connector+solder for this many wires or is the method I am using just fine?
I thought about making a thin 1/4" inch x 1" two rail circuit board to solder all wires too and then shrink that to the wires.
Think Inside the box first and if that doesn't work..
Think outside the BOX!
I have read what I am doing works well though.
That's how my boss asks me to put things together! "Looks like it'll do the job....how will you fix it when it breaks...?" hehe As always, a bit of extra time filling in the 'short cuts' will make things easier down the road!
Steve
