Pin outs on AppMod headers?
I'm using a BSAC basic stamp activity kit board, and a BS2sx.
On the board, there is an AppMod header that has 2 rows of 10 Pins.
I would like to interface to this header, but can't seem to find the
pin mapping to the BS2sx chip.· I checked the on-line documentiation for this board
but it does not seem to have a map of which pin on the BS2sx goes to which socket on the header.
Can someone provide a list of which pins on the header go to which pins on the BS2sx?
David
David
Sid
Sid Weaver
Don't have VGA?
Newzed@aol.com
On the board it says·:
··········2·····················20
·········· 0 0 0 0 0 0 0 0 0 0
·········· 0·0 0 0 0 0 0 0 0 0
··········1·······················19
But how do I know which sockets on the appmod header go to what pins on my chip?
The BS2sx pinout is:
Pin······ Name
1········ SOUT
2········ SIN
3······· ATN
4······· VSS
5-20··· P0-P15
21······ VDD
22·······RES
23······ VSS
24······ VIN
David
Post Edited (tripjack) : 11/21/2006 3:51:48 PM GMT
Sid
Sid Weaver
Don't have VGA?
Newzed@aol.com
I am using a BSAC "Basic Stamp activity board" P/n 27905 (discontinued)
David
and Vin (what voltage you supply to your board). For the actual pinout, check the documentation for
just about any of the AppMod products from Parallax. Here's a link for the SoundMod board.
http://www.sxtech.com/dl/docs/prod/appmod/SoundModManBv1_1.pdf
The pinout in on page 6, near the end of the document.
-Rusty-
Rusty Haddock = KD4WLZ = rusty@fe2o3.lonestar.org
**Out yonder in the Van Alstyne (TX) Metropolitan Area**
Microsoft is to software what McDonalds is to gourmet cooking
Let me know if the header checks out like that.
Sid
Sid Weaver
Don't have VGA?
Newzed@aol.com
··· This was solved by phone this morning...However, for reference, the schematic is attached.· Take care.
The BOE pinouts are here:
http://www.parallax.com/images/prod_jpg/28150.jpg
Sid your mapping is correct as far as Pin 1 & 2 being VSS (ground), Pin 20 being VIN (unregulated) and Pin 19 being VDD (+5V).· I will do as you suggest and assume pins 3-17 are Stamp I/O even numbers and test it.
Thanks a million!
David
