What is a "Super Cap"
KatyBri
Some IC's, such as the DS1302 time keeping chip, call for a "super cap" for battery backup. What does "super cap" mean? Thanks.
A super cap is simply a capacitor that has a large "capacity", in the order of 1 or more farads. A search on google will return a few of these.
You can find them on eBay as well.
-Ben
If you use large value caps "super caps", I would expect the resting voltage on these caps could get pretty high. Do you have to worry about this voltage exceeding the max allowable voltage of the IC pin it is attached to?
The voltage of a cap will never be higher than the highest voltage of the bus the cap is on, at least in a super cap battery backup replacement application. If you have good regulation when powered, it should be a non-issue.
Yours, Tom P
KatyBri, the capacitor will hold the voltage at the level you charged it...
...just to make sure you can tell us about it. ;^)
Yours, TDP
