word hex counter
I have been working on displaying word variables and I am having trouble with this Hex counter. It only displays two digits the right most digit counts (0 – F) as I expected but the left most digit only advances every 256 counts. I cannot get it to display four digits. What am I missing.
·Mike W
DEVICE········· SX28, OSCXT2, TURBO, STACKX, OPTIONX
FREQ··········· 4_000_000
' IO Pins
Lcdout········· VAR···· RA.0··················· ' output to Parallax LCD
' Constants
LcdBaud·········· CON···· "T19200"········· ' or T2400, or T9600
LcdCls·············CON······ ·$0C············ ·' clear LCD (need 5 ms delay)
LcdCR············· CON····· ·$0D············ ·' move pos 0 of next line
LcdOn1··········· CON·······$16············ ·' LCD on; no crsr, no blink
LcdLine0Pos0··· CON····· ·$80············ ·' move to line 0, position 0
LcdLine1Pos0··· CON····· ·$94············ ·' move to line 1, position 0
' Variables
temp1·········· VAR···· ·Byte···················
counter········ VAR····· Word
wTemp1······· VAR····· Word
wTemp2······· VAR····· Word
wTemp3······· VAR····· Word
wTemp4······· VAR····· Word
' Subroutine DECLARATIONS
GET_HEX ·SUB·1, 3············· ' print using HEXx format
LCD_OUT········ SUB···· 1, 2···' send to LCD
' Program Data
· PROGRAM Start
' Program Code
Start:
· PLP_A = %0001································ ' pull up unused pins
· PLP_B = %00000000
· PLP_C = %00000000
· HIGH Lcdout ··································· ' make lcd output pin high
· pause 100······································· ' let LCD initialize
·· LCD_OUT LcdCls
·· LCD_OUT LcdOn1
· pause 5
Main:
· for counter = 0 to 65535
··· if counter = 65535 then
···· end
··· endif
·· LCD_OUT LcdLine1Pos0
·· GET_HEX counter, 4
pause 250
· next
goto Main
' Subroutines / Jump Table
LCD_OUT:
· temp1 = __PARAM1··································· ' digit to send
· SEROUT Lcdout, LCDBaud, temp1················· ' send the digitacter
· RETURN
GET_HEX:
· wTemp2 = __WPARAM12······························' copy output value
· IF __PARAMCNT = 2 THEN
··· IF __WPARAM23 = 1 THEN Low_Nib
· ENDIF
· SWAP wTemp2·········································· ' move high nib
· wTemp3 = wTemp2 & $0F·························· ·' make pointer
· READ Hex_Digit + wTemp3, wTemp1·········· ····' get NIB1 digit
· LCD_OUT wTemp1··································· ·· ' print it
· SWAP wTemp2·········································· ' restore low nib
Low_Nib:
· wTemp3 = wTemp2 & $0F··························· ' make digit pointer
· READ Hex_Digit + wTemp3, wTemp1·············· ' get NIB0 digit
· LCD_OUT wTemp1····' print it
· RETURN
Hex_Digit:
· WDATA·"0123456789ABCDEF"
·Mike W
' IO Pins
' Constants
' Variables
' Program Data
· PROGRAM Start
' Program Code
Start:
· PLP_B = %00000000
· PLP_C = %00000000
·· LCD_OUT LcdCls
·· LCD_OUT LcdOn1
· pause 5
Main:
···· end
··· endif
pause 250
· next
goto Main
LCD_OUT:
· RETURN
GET_HEX:
· ENDIF
Low_Nib:
· RETURN
Hex_Digit:
I think the problem is how you are using __PARAMCNT.
__PARAMCNT holds the number of bytes being passed to the subroutine. So if you pass a word (as you are) that will make __PARAMCNT = 2 (since a word is two bytes).
Also, when you SWAP a word variable, it swaps the high and low BYTES. If you want to swap the nibbles you need to add the _LSB or _MSB postfix.
SWAP wTemp2_LSB
Terry
Stuff I'm selling on ebay http://search.ebay.com/_W0QQsassZhittconsultingQQhtZ-1
"People who are willing to trade their freedom for·security deserve neither and will lose both." Benjamin Franklin
Although I am still confused here is what I did.
I removed the lines·················· IF· __PARAMCNT = 2 THEN
·················································· IF __WPARAM23 = 4 THEN Low_Nib
················································ ENDIF
Then changed GET_HEX as shown below
I now get three digits but cannot figure out why I cannot get four
GET_HEX:
· wTemp4 = wTemp2_MSB & $0F············· ···········
·· READ Hex_Digit + wTemp4, wTemp1·········· ···········
· LCD_OUT wTemp1·········· ······················· ···········
SWAP wTemp2_LSB·························································
· wTemp3 = wTemp2_LSB & $0F·····································
·· READ Hex_Digit + wTemp3, wTemp1···························
· LCD_OUT wTemp1························································
· SWAP wTemp2_LSB······················································
Low_Nib:
· READ Hex_Digit + wTemp3, wTemp1·····························
· LCD_OUT wTemp1·························································
· RETURN
Mike W
DEVICE SX28, OSCXT2, TURBO, STACKX, OPTIONX FREQ 4_000_000 ' ------------------------------------------------------------------------- ' IO Pins ' ------------------------------------------------------------------------- Lcdout PIN RA.0 OUTPUT ' output to Parallax LCD ' ------------------------------------------------------------------------- ' Constants ' ------------------------------------------------------------------------- LcdBaud CON "T19200" ' or T2400, or T9600 LcdCls CON $0C ' clear LCD (need 5 ms delay) LcdCR CON $0D ' move pos 0 of next line LcdOn1 CON $16 ' LCD on; no crsr, no blink LcdLine0Pos0 CON $80 ' move to line 0, position 0 LcdLine1Pos0 CON $94 ' move to line 1, position 0 ' ------------------------------------------------------------------------- ' Variables ' ------------------------------------------------------------------------- temp1 VAR Byte counter VAR Word wTemp1 VAR Word ' ------------------------------------------------------------------------- ' Subroutine DECLARATIONS ' ------------------------------------------------------------------------- GET_HEX SUB 2 ' print using HEXx format LCD_OUT SUB 1, 2 ' send to LCD ' ========================================================================= ' Program Data ' ========================================================================= PROGRAM Start ' ========================================================================= ' ------------------------------------------------------------------------- ' Program Code ' ------------------------------------------------------------------------- Start: PLP_A = %0001 ' pull up unused pins PLP_B = %00000000 PLP_C = %00000000 HIGH Lcdout ' make lcd output pin high pause 100 ' let LCD initialize LCD_OUT LcdCls LCD_OUT LcdOn1 pause 5 Main: for counter = 0 to 65535 if counter = 65535 then end endif LCD_OUT LcdLine1Pos0 GET_HEX counter, 4 pause 250 next goto Main ' ------------------------------------------------------------------------- ' Subroutines / Jump Table ' ------------------------------------------------------------------------- LCD_OUT: temp1 = __PARAM1 ' digit to send SEROUT Lcdout, LCDBaud, temp1 ' send the digitacter RETURN ' ------------------------------------------------------------------------- GET_HEX: wTemp1 = __WPARAM12 ' copy output value temp1 = wTemp1_MSB >> 4 READ Hex_Digit + temp1, temp1 LCD_OUT temp1 temp1 = wTemp1_MSB & $0F READ Hex_Digit + temp1, temp1 LCD_OUT temp1 temp1 = wTemp1_LSB >> 4 READ Hex_Digit + temp1, temp1 LCD_OUT temp1 temp1 = wTemp1_LSB & $0F READ Hex_Digit + temp1, temp1 LCD_OUT temp1 RETURN ' ========================================================================= Hex_Digit: DATA "0123456789ABCDEF" ' -------------------------------------------------------------------------Bean.
It would have been a while before I got to shifting
I am picking apart·posted·code in an attempt to better understand SX/B I started playing with word variables and got a little stuck. Thanks for the gimmy
Mike W
