Serial vs parallel LCD — Parallax Forums
flapdoodle_dinghyflapdoodle_dinghy Posts: 17
edited 2006-11-20 16:36 in Propeller 1
What are the pros and cons of using either a serial versus a parallel text LCD with the Prop as a sort of terminal?
  • HarleyHarley Posts: 997
    The most obvious point would be number of signals needed. Parallel could take up to 8 'data' lines plus 3 control lines. Serial could be as few as 1 line.
    So for applications where there are few I/O remaining, the serial i/f would be in order.
    I've not yet used serial LCDs, quite expensive. But they are relatively slow, so parallel isn't required.
    Harley Shanko
    h.a.s. designn
