Custom PCBs
CPUMAN
I'm interested in making custom PCBs instead of using those nasty boards that radio shack sells.
I'm open to the idea of etching the boards myself but I've never done it before and it seems to be a bit of a hassle.
So mainly what I'm asking is what is your recommendations for custom PCB manufacturers and what software would you recommend for designing the boards?
Chris
Chris
Instead, I now use Alberta Printed Circuits. They're fast, cheap, and do good work. Plus, for their Proto1 service, they'll let you submit multiple and mixed boards on a single panel without charging extra just for the privilege. I highly recommend them!
If you want ultra cheap, theres www.batchpcb.com which charge $10 per order (for any number of boards) plus $2.50/sqin. They only have machine verification, the quality is adequate, it takes a while to get them (they are manufactured in China) and the silkscreen registration (alignment) can be a little off, but they are by far the cheapest I've found and for most applications it does the job adequately.
Paul Baker
The second question is can anyone recomend some good PCB design software, that perferable won't break the bank?
Thanks for the help!
Chris
I've etched myself using staples photo paper and laserjet toner and the boards turned out fine, but I wouldn't recommend doing that if you planned to produce more than 4 boards or needed very close tolerances. If you are interested in trying it yourself, there is a great guide here http://www.fullnet.com/u/tomg/gooteepc.htm
Edit: eagle webiste www.cadsoft.de/ It took me a while to figure out everything but once you get the hang of it, it's an incredibly useful tool. You can download the basic stamp 2 ic from their libraries page, the autorouter is also very useful. Here's my rfid circuit drawn in eagle.
And here's a (very simple) board layout from eagle (the traces are fairly large because I made the board myself.
Good luck!
Post Edited (Billy K) : 11/21/2006 7:40:49 AM GMT
