How to Read and write a two dimensional array in pbasic? — Parallax Forums
tripjacktripjack Posts: 13
edited 2006-11-20 23:57 in General Discussion
I'm trying to read from a table in pbasic on a BS2sx.
I loaded the following data
r0 DATA "1234", "5678"
r1 DATA "ABCD", "EFGH"
I'm noticing that the READ command only returns bytes.
so the command :
READ r1, strByte
returns 1
Can someone suggest a subroutine in pbasic that I specify the row and column of my data and it returns the whole string?·· eg: r1 c1 returns "EFGH"
David
    edited 2006-11-19 14:22
    A 2-D array: 8 cells; 2 rows, 4 cols; using ADDRs $01 - $08
    r· VAR· Nib
    c· VAR· Nib
    cell = r * c
    READ·cell, contents
    Post Edit -- You could jamb this up with bad values (r, c), but I think you get the idea.
    Post Edited (PJ Allen) : 11/19/2006 2:28:29 PM GMT
  • tripjacktripjack Posts: 13
    THANKS PJ for putting me on the right track
    I used this code and it works great!
    MaxCols CON   8                  ' number of cols in table
    ColB    CON   4                  ' width of each column in bytes
    RowB    CON   ColB * MaxCols     ' width of each row in bytes
    addrW   VAR  WORD                 'output returned value
    nRow    VAR  BYTE                 'input row number
    nCol    VAR  BYTE                 'input column number
    addrW = ((nRow*RowB) +(nCol * ColB))
    David
