What is the differance between SPI and I2C
When we use shiftout to have stamp talk to the max 7219 display driver, is this· SPI communication or I2C?· When we use·a LCD display and serout (Asynschronous)· can i use this command to drive a 5x7 LED display· with the max6954 (SPI)··driver. The max web site has·a example but the program is for PIC.·· Is there· a way to·convert PIC·language to basic?· Where· can I get a book or info on these subjects· thanks· jonw
EDIT >>>· Also· on maxim site· there is lots of talk of· 2 wire interface,··· Which protocol is this·· Thanks
Post Edited (jonw) : 11/19/2006 3:29:21 AM GMT
············· NEW Topic >>· On a 5x7 display What does cathode Row mean? (Maxim term)
·· I think it means all that row has their cathodes common.· Is this the same as saying column common ·anode · then (led american bright· term)?
····················· thanks· jonw
Even though I2C is not natively supported by the BS2, you can still use it with appropriately-crafted subroutines. Check out this forum thread.
