byte questions — Parallax Forums
byte questions
RontopiaRontopia Posts: 139
edited 2006-11-19 17:30 in BASIC Stamp
hi all
Im working with a BS2 and as we all know there are 32 bytes of ram for var's
my question is about the definition of byte as 0 to 255.. does this mean that a bite can be -128 to + 128.. or 127. Or does a byte have to be 0 to 255?
Muahdib
IC layout designer
Phoenix Arizona
  • RontopiaRontopia Posts: 139
    edited 2006-11-17 20:03
    sorry .. one more thing.. can byte be any value with 3 digits.. like .01 or .001
    thanks
    Muahdib
    IC layout designer
    Phoenix Arizona
  • Beau SchwabeBeau Schwabe Posts: 6,574
    edited 2006-11-17 20:17
    Muahdib,
    A Byte can only be an integer value from 0 to 255.
    Beau Schwabe
    IC Layout Engineer
  • Randy EvansRandy Evans Posts: 24
    edited 2006-11-17 20:20
    A byte is 8-bits, or 2 to the power of 8. 00 - FF Hexadecimal. However you want to represent that is up to you.
    Randy
    edited 2006-11-17 21:07
    thanks guys,
    while I dont understand the hexadecimal stuff.. I understand that it must be an integer between 0 to 255 or 2 to the power of 8.
    Muahdib
    IC layout designer
    Phoenix Arizona
  • TechnoRobboTechnoRobbo Posts: 323
    Actually what Randy told you is correct.· A byte has 256 states addressed together not numbers.· They are numbers when you treat them like numbers. They are also signed (negative and positive) When you treat them·like signed numbers.
    Adventures in Binary Math
    Like the decimal system the binary system can have negative or positive numbers depending whether you use the highest bit as a negative sign. Either way the math works the same.·
    When you add in binary you carry the bit when the answer is greater than 1.· You also borrow the bit when the answer is less than zero. So it looks like this:
    subtraction
    ···· 00000000··· zero
    ··· -00000001··· minus one
    ···· 11111111····equals negative one - note that the highest bit is on.
    addition
    ···· 11111110·· negative two
    ··· +00000011· plus three
    ···· 00000001·· equals 1
    Actually it equals 100000001 (decimal 257) but since a byte has only 8 bits you loose the ninth (left) bit and Eureka!!!! you got the right answer.
    Please Note: If the memory was addressed as a WORD (16 bits)·the ninth bit·would not be imaginary. Working with an imaginary bit is·an overflow if it yields the wrong result.
    The easiest way to convert an unsigned byte to a signed byte is to look if the sign bit is "on" and if it is subtract the value from 256.
    Multiplication and division follow the same rules as in the decimal world and floating point math is the·ultimate methodology for higher mathematics.· But before you try to "normalize" a number·try doing some research.
    I'm only scratching the surface of binary math, a subject that is way beyond the scope of this "post",·so I would suggest buying a good book on the subject.
    Here's the list of· values for a byte.
    Byte Values:
    Binary··· unsigned signed
    00000000······ 0············ 0
    00000001······ 1············ 1
    00000010······ 2············ 2
    00000011······ 3············ 3
    00000100······ 4············ 4
    00000101······ 5············ 5
    00000110······ 6············ 6
    00000111······ 7············ 7
    00001000······ 8············ 8
    00001001······ 9············ 9
    00001010······ 10··········· 10
    00001011······ 11··········· 11
    00001100······ 12··········· 12
    00001101······ 13··········· 13
    00001110······ 14··········· 14
    00001111······ 15··········· 15
    00010000······ 16··········· 16
    00010001······ 17··········· 17
    00010010······ 18··········· 18
    00010011······ 19··········· 19
    00010100······ 20··········· 20
    00010101······ 21··········· 21
    00010110······ 22··········· 22
    00010111······ 23··········· 23
    00011000······ 24··········· 24
    00011001······ 25··········· 25
    00011010······ 26··········· 26
    00011011······ 27··········· 27
    00011100······ 28··········· 28
    00011101······ 29··········· 29
    00011110······ 30··········· 30
    00011111······ 31··········· 31
    00100000······ 32··········· 32
    00100001······ 33··········· 33
    00100010······ 34··········· 34
    00100011······ 35··········· 35
    00100100······ 36··········· 36
    00100101······ 37··········· 37
    00100110······ 38··········· 38
    00100111······ 39··········· 39
    00101000······ 40··········· 40
    00101001······ 41··········· 41
    00101010······ 42··········· 42
    00101011······ 43··········· 43
    00101100······ 44··········· 44
    00101101······ 45··········· 45
    00101110······ 46··········· 46
    00101111······ 47··········· 47
    00110000······ 48··········· 48
    00110001······ 49··········· 49
    00110010······ 50··········· 50
    00110011······ 51··········· 51
    00110100······ 52··········· 52
    00110101······ 53··········· 53
    00110110······ 54··········· 54
    00110111······ 55··········· 55
    00111000······ 56··········· 56
    00111001······ 57··········· 57
    00111010······ 58··········· 58
    00111011······ 59··········· 59
    00111100······ 60··········· 60
    00111101······ 61··········· 61
    00111110······ 62··········· 62
    00111111······ 63··········· 63
    01000000······ 64··········· 64
    01000001······ 65··········· 65
    01000010······ 66··········· 66
    01000011······ 67··········· 67
    01000100······ 68··········· 68
    01000101······ 69··········· 69
    01000110······ 70··········· 70
    01000111······ 71··········· 71
    01001000······ 72··········· 72
    01001001······ 73··········· 73
    01001010······ 74··········· 74
    01001011······ 75··········· 75
    01001100······ 76··········· 76
    01001101······ 77··········· 77
    01001110······ 78··········· 78
    01001111······ 79··········· 79
    01010000······ 80··········· 80
    01010001······ 81··········· 81
    01010010······ 82··········· 82
    01010011······ 83··········· 83
    01010100······ 84··········· 84
    01010101······ 85··········· 85
    01010110······ 86··········· 86
    01010111······ 87··········· 87
    01011000······ 88··········· 88
    01011001······ 89··········· 89
    01011010······ 90··········· 90
    01011011······ 91··········· 91
    01011100······ 92··········· 92
    01011101······ 93··········· 93
    01011110······ 94··········· 94
    01011111······ 95··········· 95
    01100000······ 96··········· 96
    01100001······ 97··········· 97
    01100010······ 98··········· 98
    01100011······ 99··········· 99
    01100100······ 100·········· 100
    01100101······ 101·········· 101
    01100110······ 102·········· 102
    01100111······ 103·········· 103
    01101000······ 104·········· 104
    01101001······ 105·········· 105
    01101010······ 106·········· 106
    01101011······ 107·········· 107
    01101100······ 108·········· 108
    01101101······ 109·········· 109
    01101110······ 110·········· 110
    01101111······ 111·········· 111
    01110000······ 112·········· 112
    01110001······ 113·········· 113
    01110010······ 114·········· 114
    01110011······ 115·········· 115
    01110100······ 116·········· 116
    01110101······ 117·········· 117
    01110110······ 118·········· 118
    01110111······ 119·········· 119
    01111000······ 120·········· 120
    01111001······ 121·········· 121
    01111010······ 122·········· 122
    01111011······ 123·········· 123
    01111100······ 124·········· 124
    01111101······ 125·········· 125
    01111110······ 126·········· 126
    01111111······ 127·········· 127
    10000000······ 128········· - 128
    10000001······ 129········· - 127
    10000010······ 130········· - 126
    10000011······ 131········· - 125
    10000100······ 132········· - 124
    10000101······ 133········· - 123
    10000110······ 134········· - 122
    10000111······ 135········· - 121
    10001000······ 136········· - 120
    10001001······ 137········· - 119
    10001010······ 138········· - 118
    10001011······ 139········· - 117
    10001100······ 140········· - 116
    10001101······ 141········· - 115
    10001110······ 142········· - 114
    10001111······ 143········· - 113
    10010000······ 144········· - 112
    10010001······ 145········· - 111
    10010010······ 146········· - 110
    10010011······ 147········· - 109
    10010100······ 148········· - 108
    10010101······ 149········· - 107
    10010110······ 150········· - 106
    10010111······ 151········· - 105
    10011000······ 152········· - 104
    10011001······ 153········· - 103
    10011010······ 154········· - 102
    10011011······ 155········· - 101
    10011100······ 156········· - 100
    10011101······ 157········· - 99
    10011110······ 158········· - 98
    10011111······ 159········· - 97
    10100000······ 160········· - 96
    10100001······ 161········· - 95
    10100010······ 162········· - 94
    10100011······ 163········· - 93
    10100100······ 164········· - 92
    10100101······ 165········· - 91
    10100110······ 166········· - 90
    10100111······ 167········· - 89
    10101000······ 168········· - 88
    10101001······ 169········· - 87
    10101010······ 170········· - 86
    10101011······ 171········· - 85
    10101100······ 172········· - 84
    10101101······ 173········· - 83
    10101110······ 174········· - 82
    10101111······ 175········· - 81
    10110000······ 176········· - 80
    10110001······ 177········· - 79
    10110010······ 178········· - 78
    10110011······ 179········· - 77
    10110100······ 180········· - 76
    10110101······ 181········· - 75
    10110110······ 182········· - 74
    10110111······ 183········· - 73
    10111000······ 184········· - 72
    10111001······ 185········· - 71
    10111010······ 186········· - 70
    10111011······ 187········· - 69
    10111100······ 188········· - 68
    10111101······ 189········· - 67
    10111110······ 190········· - 66
    10111111······ 191········· - 65
    11000000······ 192········· - 64
    11000001······ 193········· - 63
    11000010······ 194········· - 62
    11000011······ 195········· - 61
    11000100······ 196········· - 60
    11000101······ 197········· - 59
    11000110······ 198········· - 58
    11000111······ 199········· - 57
    11001000······ 200········· - 56
    11001001······ 201········· - 55
    11001010······ 202········· - 54
    11001011······ 203········· - 53
    11001100······ 204········· - 52
    11001101······ 205········· - 51
    11001110······ 206········· - 50
    11001111······ 207········· - 49
    11010000······ 208········· - 48
    11010001······ 209········· - 47
    11010010······ 210········· - 46
    11010011······ 211········· - 45
    11010100······ 212········· - 44
    11010101······ 213········· - 43
    11010110······ 214········· - 42
    11010111······ 215········· - 41
    11011000······ 216········· - 40
    11011001······ 217········· - 39
    11011010······ 218········· - 38
    11011011······ 219········· - 37
    11011100······ 220········· - 36
    11011101······ 221········· - 35
    11011110······ 222········· - 34
    11011111······ 223········· - 33
    11100000······ 224········· - 32
    11100001······ 225········· - 31
    11100010······ 226········· - 30
    11100011······ 227········· - 29
    11100100······ 228········· - 28
    11100101······ 229········· - 27
    11100110······ 230········· - 26
    11100111······ 231········· - 25
    11101000······ 232········· - 24
    11101001······ 233········· - 23
    11101010······ 234········· - 22
    11101011······ 235········· - 21
    11101100······ 236········· - 20
    11101101······ 237········· - 19
    11101110······ 238········· - 18
    11101111······ 239········· - 17
    11110000······ 240········· - 16
    11110001······ 241········· - 15
    11110010······ 242········· - 14
    11110011······ 243········· - 13
    11110100······ 244········· - 12
    11110101······ 245········· - 11
    11110110······ 246········· - 10
    11110111······ 247········· - 9
    11111000······ 248········· - 8
    11111001······ 249········· - 7
    11111010······ 250········· - 6
    11111011······ 251········· - 5
    11111100······ 252········· - 4
    11111101······ 253········· - 3
    11111110······ 254········· - 2
    11111111······ 255········· - 1
    Have Fun
    TR
