Toothpick and VB
Bill Chennault
All--
I have devoured the Toothpick documentation on the Parallax website. And, I have read the accompanying pdf description. Neither seem to tell me that I can use VB and a Stamp with Toothpick in the middle to add real-time processing power (reading from Stamp inputs, making descisions, writing to Stamp outputs) to my robot. Does anyone know if VB sees the Toothpick as a serial port?
Plus, I did a search on the Toothpick on these forums and found some material, but none of it appeared to address my specific question. (There was some rather amusing acrimonious discussion, however!)
Thank you in advance for any help you provide.
--Bill
You are what you write.
--Bill
·· The Toothpick allows a serial connection via Blue Tooth as well as a few functions that can be accessed via commands from a connected BASIC Stamp.· There is no reason you cannot write a VB program to open the Virtual Serial Port created by the BT Driver and send commands and get data from a BASIC Stamp connected to the Toothpick.· I hope this helps.· Take care.
Yes. It helps. What helps more is the integrated support available to newbies (like me) from Parallax.
Thank you.
--Bill
