How do you store your resistors? — Parallax Forums
Brian GrimmBrian Grimm Posts: 7
edited 2006-12-21 15:09 in General Discussion
Greetings all!
I've just received a resistor assortment which contains a metric buttload (100 ea. x 161 values)·of 1/4 watt standard resistors on tape.· I've gone through and marked the value on the tape, but right now I'm just sticking them back into the bags they came in.· Through advanced scientific methods, I've determined that the bags will last about one more use (they are a tight fit.)
I've considered stripping them off the tape and using little parts drawers, or just putting them into gallon zipper bags, sorted by decades, but I'm interested in how everyone else is dealing with them.
Brian, N7QJB
  • stamptrolstamptrol Posts: 1,731
    edited 2006-11-15 20:46
    Brian,
    Just about a gazillion ways to skin this cat!
    I use small parts drawers to hold the most common ones I use: 100, 220, 330, 470, 1K, 2.2K, 3.3K, 4.7K, 10K
    In another set of drawers I put all the brown-blacks (10's), 12's, 15's, etc, etc, etc. That way, when you need one of the values not in the "favorites", you're only looking for the third color band. For example, if you need 15K, open the 15 drawer and look for the orange band in the 3rd position.
    This presumes a working knowledge of the resistor color code, of course!
    Cheers
    Tom Sisk
    http://www.siskconsult.com
  • John R.John R. Posts: 1,376
    edited 2006-11-15 21:42
    I use some of the "flat" plastic tackle boxes. For "lots" of separate compartments, I find them "denser" per compartment than the parts drawers. In some ways I like them better than the parts drawers, in others not.
    When you open one of these units, all the compartments are open, and subject to the cat, wife, bird, etc., helping you make a mess. This same feature makes multiple parts easier to pull.
    I've got 3 of these with two values of resistors in each compartment. It started off with two 1/4 watt assortments from Digi-key, I'm not at home, and forgot the range and number of values, but it's basically every step on the scale.
    I've also printed out a sheet of labels with the values and color codes for each "case".
    John R.
    8 + 8 = 10
  • Steve JoblinSteve Joblin Posts: 784
    edited 2006-11-15 22:22
    I built a small box that was just wide enough to fit an envelope.... I then put each value in a seperate envelope.· Now I have a little "filing" cabinet sorted by values!
  • BeanBean Posts: 8,129
    edited 2006-11-15 23:24
    At home I store 10 ohm, 100 ohm, 1K, 10K, 100K and 1M seperately. Then I put the rest in draws by the third band color. So everything that has a black third band goes in one draw (except 10ohm), then everything with a brown third band (except 100Ohm) goes into another draw.
    At work we use thoses small vertical envelopes (about 2 inches wide by 4 inches high with opening at the top) and we store each value seperately. Then the envelopes are put into a box with the smallest values in the front. Then tab cards are put in at 100, 1K, 10K, 100K points.
    For SMT parts I use this from Jameco http://www.jameco.com/webapp/wcs/stores/servlet/ProductDisplay?langId=-1&storeId=10001&catalogId=10001&productId=164267
    It's a little pricey, but it has 128 little compartments with hinged lids. And it's fairly well made.
    Bean.
    "People who are willing to trade their freedom for·security deserve neither and will lose both." Benjamin Franklin
  • David BDavid B Posts: 593
    edited 2006-11-16 01:08
    I just keep a small plastic tub of all resistors to be most easily available for desktop proto-board design.
    I used to store them on my bench in separate containers by the multiplier color band, but as a hobbiest, I don't use all that many resistors overall, and now that the color code of the most commonly used resistors is burned into my brain, it's just as easy to pick whatever I need out of a single tub. Plus it takes less benchtop area.
    Ditto for small capacitors, diodes, and general purpose transistors and proto-board hookup wire. Each has a single tub. (old margerine containers)
    But it is a constant struggle to keep the containers in order, not too full, no soldered-leads, etc. And as I remove commonly used values to solder into permanant projects, the less-commonly used values tend to accumulate and have to be thinned from time to time.
    I do keep separate color-coded bins in the garage for excess, and high-wattage, and formerly soldered resistors. But that simple tub satisfies 90% of my protoboard needs.
  • LSBLSB Posts: 175
    edited 2006-11-16 05:06
    I ordered 100 perscription bottles--cost me ~$20.
    edited 2006-11-16 06:50
    Tackle box, portable and inexpensive. My favorite from ArtBin is no longer made by them, but the Plano 4-by is a decent substitute and is <$20 at Walmart's website: http://www.walmart.com/catalog/product.do?cpncode=12-15197418-2&dest=9999999997&product_id=4303556&sourceid=0100000012231186502498&srccode=cii_1038957
    Paul Baker
    edited 2006-11-16 09:38
    I use small plastic baggies.
    They are more compact. All my resistors then fit in one sandwitch baggies. Each has a lable stuck on it.
    I just go thru them like a deck of cards when I need a particular value. 1/8watt, 1/4watt, 2watt is obvious.
    I just tired of too many trays and being a librarian.
    I do the same thing with my capacitors.
    "If you want more fiber, eat the package.· Not enough?· Eat the manual."········
    ···················· Tropical regards,····· G. Herzog [noparse][[/noparse]·黃鶴 ]·in Taiwan
  • steve_bsteve_b Posts: 1,563
    edited 2006-11-16 14:16
    I just got a whole lot of drawers!!
    Actually, those drawer cases hold 60drawers with 3sections per drawer. I've got one value of resistor per drawer with 3 different wattages taking up the 3sections.
    (not all the cabinets are resistors)
    I've got a couple of small yellow cases on top that hold the 1%tolerance resistors.
    This is my "Wall O'Wonder" at work....even if I had this much wall space at home, the mrs wouldn't let me put this up!
    You'll find quickly that there are only certain resistors you'll use more frequently....so you'll probably want to keep the common items most accessible and retire the less used items to a case that's out of the way.
    cheers
    Steve
    1600 x 1200 - 446K
  • Tom WalkerTom Walker Posts: 509
    edited 2006-11-16 16:03
    Sniff...I've easily got the parts to do your wall justice, but not the organizational space...
    Sigh....
    edited 2006-11-16 17:04
    Tom Walker said...
    Sigh....
    That's exactly why I went the "tackle box" route.· I don't acutally use the "tackle boxes" per se, but the compartmentalized plastic boxes.· They come in various sizes and "depths".· I find them more "dense" in terms of "compartments per cubic inch".· I've standardized on the larger size (9 x 13 I think), and they stack up nicely in the "milk crates" from staples so they can be moved around, etc.· I keep common items hand on shelves near by, and the less frequently used (or "I don't need this but CAN'T throw it away" stuff) in the milk crates under the bench, in the closet, etc.
    The drawer units·are nice, and if I had the space I'd prefer them,·but it seems like they take up too much space "per compartment".
    John R.
    8 + 8 = 10
  • SailerManSailerMan Posts: 337
    edited 2006-11-16 17:33
    Steve_B· I don't think I've ever seen that many drawers... So how do you remember where everything is? Do ya have your own catalog?· smilewinkgrin.gif
    edited 2006-11-16 20:01
    SailerMan said...
    Steve_B I don't think I've ever seen that many drawers... So how do you remember where everything is? Do ya have your own catalog? smilewinkgrin.gif
    All the drawers are labeled.
    Resistors are in their own area and diode-types in their own.
    A drawer will have a label on the front like "74133"...open it up and of the 3compartments, there'll be 2 more labels for them (ie. middle compartment "74134"; last compartment "74135"). It was put together with some sense of organizing (by a previous co-worker) but there are some areas where you just have to get in and search....these were mostly parts scavanged from old gear that don't really have a home.
    Have some basic hardware in there (screws/grommets/etc..). Makes things easier for sure...I do a lot of my personal projects here for when I don't have "that" item!
    Steve
    edited 2006-11-16 20:11
    steve_b,
    Just out of curiosity... Where did you get the 5x12 blue drawers?
    I have 5 of them myself plus 6 5x4's and would like a few more, but my original supplier no longer caries them.
    If I remember right they go for about $20 a pop.
    SailerMan,
    "...So how do you remember where everything is? Do ya have your own catalog?..."
    http://forums.parallax.com/showthread.php?p=549166
    Pointed at this....
    http://forums.parallax.com/showthread.php?p=531927
    Beau Schwabe
    IC Layout Engineer
    Post Edited (Beau Schwabe (Parallax)) : 11/16/2006 8:33:15 PM GMT
    edited 2006-11-16 23:51
    Beau... I saw that laser pointer project and thought it was a really unique project.· I also like the other link... Looking at the desk at parallax made me jealous.. What I wouldn't give to to work with electronics all day!!
    hop.gif·
    edited 2006-11-17 00:05
    For the drawer-organized sets of resistors, what do you do if you need to add a value in between somewhere? Do you have a kid who can move every drawer down, to the right, or to the next set? Or, is the approach to not keep them in order of values at some point?
    edited 2006-11-17 00:12
    Ken,
    Good point.... That is EXACTLY what happens, eventually things settle and there are simply no more practical resistor values to add· ... You play "shuffle the drawers" on some rainy weekend until then.smilewinkgrin.gif
    Beau Schwabe
    IC Layout Engineer
  • FlyingFishFingerFlyingFishFinger Posts: 461
    edited 2006-11-17 01:25
    Aah...those component organizations are making me want a real lab space...[noparse]:p[/noparse]
    Not that I have the space, time and parts to fill something like that though...but I wouldn't expect too much from a high-school junior, would you?
    I move between the garage workspace and the computer workspace. I have an old HP Omnibook with a half-defective (hence the external one) keyboard on my homework desk, that moves to the garage sometimes. We're supposed to have internet in the garage...I made sure I ran some wire there when we were remodeling, but I haven't got around to connecting it yet.
    Yeah...sometimes I wish I had a new soldering iron too...there's lots of things that could be added, even at my age.
    Otherwise, I spend a lot of time at this computer (2nd pic), for the programming and internet. It's the same one·I use for all·my homework and that my brothe·uses for his·games (see Myst in the picture). It's actually in the dining·room (well not quite). Yeah that's my 2 cents worth...sorry for getting this thread off topic a bit, but I didn't reallt feel like recalling the old ones...tongue.gif
    Rafael
    You've got to play the game.
    You can't win.
    You can't break even, except on a very cold day.
    It doesn't get that cold.
    ~Laws of Thermodynamics~
    Post Edited (FlyingFishFinger) : 11/17/2006 1:30:27 AM GMT
    1600 x 1200 - 594K
    1600 x 1200 - 573K
    1152 x 864 - 716K
    edited 2006-11-17 05:55
    Brian,
    Whichever route you choose, if you "strip them off the tape", be sure to cut them off, leaving the ends in the tape. Tin snips work great for this. The reason for doing this instead of pulling them out is the adhesive residue remaining on the wires, which can really screw up a solder joint if it becomes lodged in a through-hole. I learned this the hard way.
    edited 2006-11-17 19:17
    Beau Schwabe (Parallax) said...
    steve_b,
    Hi Beau,
    my old co-worker picked them up. some at different times (looking at the different shades of blue)....I don't think he could get them anymore either. These ones are all metal cases (with plastic drawers) and all I can find now are plastic ones (and not in the same size).
    SailerMan,
    Pointed at this....
    Steve
    edited 2006-11-17 19:52
    Steve,
    "Hi Beau,
    my old co-worker picked them up. some at different times (looking at the different shades of blue)....I don't think he could get them anymore either. These ones are all metal cases (with plastic drawers) and all I can find now are plastic ones (and not in the same size)."
    Thanks, that's what I have found out as well.... no metal, all plastic. Hmmmm?
    Beau Schwabe
    IC Layout Engineer
  • Brian GrimmBrian Grimm Posts: 7
    edited 2006-11-30 03:16
    Thanks to everyone who replied.· It looks like I'll try a combination of things.· I've got a number of drawers available from the capacitor assortments that I ordered at the same time, so I'll put some of the most often used ones in there, and the rest some other way.
    Also, thanks for the link to the workshop descriptions.· I found one accidentally while looking for some woodworking information.· The builder even posted layout diagrams for those of you so inclined.· Its at http://www.davehylands.com/Wood-Working/Electronics-Workbench/.
    A jeweler's web site I frequent has a section they call the BenchExchange.· I've gotten a few ideas from them for laying out my workshop, since both involve a number of small handtools and parts.· See http://www.ganoksin.com/orchid/BenchExchange/index.htm.
    Thanks again to everyone,
    Brian, N7QJB
  • PLJackPLJack Posts: 398
    edited 2006-12-01 20:06
    That first work bench is amazing.
    I often wonder how much of my "bench time" is wasted looking for components.
    On some days I bet it is in the 30 to 40 percent range.
    - - - PLJack - - -
    Perfection in design is not achieved when there is nothing left to add.
    It is achieved when there is nothing left to take away.
  • saunjsaunj Posts: 1
    edited 2006-12-20 03:05
    I store my considerable stock of (mostly old) resistors in drawers, in half-decades (1 to 3.2 is a half decade, 3.3 to 9.9 is the next) for 1/2 and 1/4 watt. I have a second set for 1% resistors and a third for higher powers. Like you, have some in bulk on tape. I pull out a few and put them in the drawers for easy finding.
  • AImanAIman Posts: 531
    Guess I'm the lazy one in the group.
    I simply buy the resistors or capacitors about 2 dozen at a time and throw them into a zip lock bag with the store label. When I need the item I pull the bags and look for the factory packing. All I do is leave them in a row from smallest to largest.
