using 2 serout with different pins
Hello,
I am using an sx28 with a ds1620,serial display, and a pink.
i am using 2 different serial routines 1 for the pink and 1 for the serial display.
I have noticed that when i use both serial routines in the program , that the sx get stuck or doesn't send the correct data to the serial display.
How much power is needed for the pink and the lcd and sx?
have somebody any idea why?
Kurt
Kurt
Bean.
"People who are willing to trade their freedom for·security deserve neither and will lose both." Benjamin Franklin
·· PINK current draw is typically ~165 mA.· I hope this helps.
there was a bad contact between the test board and the serial display.
