transferring stamp sx basic to compile sx/b
I been transferring some program from parallax stamp basic to sx/b compile basic,
and the following basic statement below cannot be be compile but works in stamp basic;
i var byte
addr var byte
chr var byte
start:
addr = msg1
gosub display_line
addr = msg2
gosub display_line
end
display_line:
i = 0
do
read addr + i,chr
if chr = 0 then exit
serout rb.1,T9600,chr
inc i
loop
return
msg1:
data "sample line 1",0
msg2:
data "sample line 2",0
what I get when compiling this program an "error 8, invalid parameter" for line 5
what is the equivalent command for assignning a pointer to a variable in sx/b??
thank you
i var byte
addr var byte
chr var byte
start:
addr = msg1
gosub display_line
addr = msg2
gosub display_line
end
display_line:
i = 0
do
read addr + i,chr
inc i
loop
return
msg1:
msg2:
thank you
Try using addr = @msg1 and addr = @msg2.
The @ prefix indicates that the memory address rather than the memory contents should be used.
- Sparks
Addr needs to be a WORD variable.
Bean.
"People who are willing to trade their freedom for·security deserve neither and will lose both." Benjamin Franklin
and will inform you when I'm back in the office
Vic f
