How many times can bs2 be programmed?
Simple question that I have never seen a result for. Do they have an average number before the start failing.
I often wondr this as I load and reload my code trying to fix some stupid little thing.
Have Fun
TR
It appears I have no worries about the bs2 reaching its max number of 10 million. I am sure to fry it, drop, dunk it, or crash it before then.
This is not usually a problem, but some people have been known to loop on a WRITE. If you do it once a millisecond (as the BS2 can do) you can wear it out in a matter of hours. So as long as you don't do that, you should be fine.
So, if you have a 'burn, test, oops, fix, recode, reburn, retest' cycle of 5 minutes or so, you can keep that up for years before wearing out the eeprom.
