FM24C64 I2C help
i'm have trouble with my read write routines with my first I2C external memorty application.
i got the code from the sx/b help file but its not working.
any help?
tech doc
http://www.ramtron.com/lib/literature/datasheets/FM24C64ds_r3.0.pdf
engineer, fireman, bowler, father, WoW addict [noparse];)[/noparse]
Post Edited (nick bernard) : 11/14/2006 9:34:41 PM GMT
any help?
tech doc
Dave
I have been hoping to try them out.
"If you want more fiber, eat the package.· Not enough?· Eat the manual."········
mouser. they have a few readily available.
arg so i have a hardware problem!
Does FRAM 0 work OK? Can you remove one of the FRAM chips and verify whether the other works by itself? Does your circuit look like the one in the spec sheet where you have external 1.8K pull-up resistors on the clock and data lines? It would be useful if you could post your circuit diagram.
Dave
I have purchased SOIC-20 adapter boards·and cut them in half with a small hacksaw.· Then I finish the sides with emery paper.· The result is two boards to adapt SOIC-8 to 0.1pin spacing.
This worked out nicely from me because the SOIC-8 devices are light sensors and I could not do the 'dead bug' trick.· In the 'dead bug'·trick, you turn the Soic-8 upside-down and solder each lead to an empty 8 Pin DIP socket with some 30 guage wire wrap wire.
I am beginning to not fear surface mount.· I even was able to bridge a 0.1uf capacitor between Vss and Vdd·on the halved adapter boards.
i'm using 2.2k pullups
i found the problem. it was hardware related.
i assembled another pcb with a hotplate reflow & solder paste and it works fine
tyvm guys!
