Unsubscribe from this thread
Folks -
What is the forum function "unsubscribe from this thread" actually supposed to do? Is it supposed to supress the email output from that particular thread?
How can one confirm that one is no longer subscribed to that particular thread? If the answer is to use the subscribed forum/thread feature of Control Panel, does the ABSENCE of the thread in question indicate that the unsubscribe was successful?
If all of the above is true, and one still receives email from that given thread, what's the next step?
On another topic entirely, if I am using IE to access the forum, and am logged in, why do I have to log in again if I switch over to another browser - Opera in my case?
TIA
Bruce Bates
TIA
Bruce Bates
stand back! I have a slide rule and I know how to use it!
Thanks for refreshing my memory. Of course it has to work that way!
I think I need more coffee this morning
Bruce Bates
<!--StartFragment -->
The third subscription class behaves somewhat like a list server. A subscription in the class will cause the site to generate an email for each new post to the subscribed forum.
If one is receiving email when not apparently subscribed to the thread or forum, one should contact the forum admin. The forum admin can examine additional system settings and logs to help determin the cause.
Jim
Parallax IT Dept.
There are only three things you need to know to survive a job.
1) Always clearly label your lunch
2) Never sleep where anyone can see you
3) Always look busy when not sleeping
