Flashing bulb
I have a flashing light bulb in parallel with a steady burning one powered by a regulated DC power supply. How come when the flashing light turns on the steady one dims slightly? I tried several capacitor values but they seem to make no noticable difference. Without the regulator the problem is worse.
Well well, I'm seeing things, three of them.
-Stanley Blystone
-Stanley Blystone
You can confirm this by using a meter or 'scope across the bulbs.
Similarly, if each bulb had its own set of wires running back to the regulator, the only change in voltage that would be observed would be that of the regulator.
Tom Sisk
http://www.siskconsult.com
-Stanley Blystone
Post Edited (Three of Them) : 11/12/2006 2:56:13 AM GMT
Post Edited (PJ Allen) : 11/12/2006 4:21:17 AM GMT
Thanks guys.
-Stanley Blystone
How about increasing the wire size in order to reduce the resistance? While 22 Ga is probably fine for the 3 Amps, it will have some resistance, especially if there is any meaningful length involved. How about replacing with 16 Ga?
John R.
8 + 8 = 10
