SX48 RD as output pins won't go high
I'm using the SX48 Proto Board (I like it a lot!) but I'm having trouble getting the RD output pins to go high. With the code that follows the RE pins go high just fine, but all the RD pins stay low.· I've tried two different boards, with same result, so I suspect it's something I'm doing rather than a static zapped board.· Here's my stripped down code...
Device Settings
DEVICE········· SX48, OSCHS3
FREQ··········· 50_000_000
ID············· "JCC"
IO Pins
Leds··VAR·RDE
Constants
Word Variables
Byte Variables
Bit Variables
Interrupt Handler
INTERRUPT 100_000
GOTO HandleInterrupt
Start of Program
PROGRAM Start
Subroutine Declarations·······················
Interrupt Handler Code
HandleInterrupt:
RETURNINT································
Initialization
Start:
· TRIS_A = %0000··'
· TRIS_B = %00000000··'
· TRIS_C = %00000000··'
· TRIS_D = %00000000··'
· TRIS_E = %00000000··'
Main Loop
Main:
· Leds = %11111111_11111111
· Pause 500
GOTO Main
Subroutines
User Data
Pgm_ID:
· DATA· "Testing", 0
Device Settings
IO Pins
Leds··VAR·RDE
Constants
Word Variables
Byte Variables
Bit Variables
Interrupt Handler
INTERRUPT 100_000
Start of Program
PROGRAM Start
HandleInterrupt:
Initialization
Start:
· TRIS_A = %0000··'
Main Loop
Main:
· Pause 500
GOTO Main
Subroutines
User Data
Pgm_ID:
Main:
· RD = Leds_MSB
· RE = Leds_LSB
· Pause 500
GOTO Main
Digging further into the assembly source output by SX/B I see the following automatically generated lines.· Look closely at the last line shown, as it seems to point the MSB of RDE to the same place in memory as the LSB of RDE...
· ; DEFINE SYSTEM VARIABLES
__RAM········ EQU· $00
RBC·········· EQU· $06
RBC_LSB······ EQU· $06
RBC_MSB······ EQU· $07
RCD·········· EQU· $07
RCD_LSB······ EQU· $07
RCD_MSB······ EQU· $08
RDE·········· EQU· $08
RDE_LSB······ EQU· $09
RDE_MSB······ EQU· $09
Later in the listing is the output for the code that doesn't seem to load RD correctly...
· MOV Leds_LSB,#%11111111_11111111 & 255 ;· Leds = %11111111_11111111
· MOV Leds_MSB,#%11111111_11111111 >> 8
What this looks like to me is that RDE_MSB and RDE_LSB are pointing to the same place, and that the compiled code is causing RE to be loaded twice accidentally.· So now the question is, is this a bug in the compiler?· Or am I looking at this goofy?
Thanks in advance for any insight!
-John
__RAM EQU $00
RBC EQU $06
RBC_LSB EQU $06
RBC_MSB EQU $07
RCD EQU $07
RCD_LSB EQU $07
RCD_MSB EQU $08
RDE EQU $08
RDE_LSB EQU $09
RDE_MSB EQU $09
That last line doesn't look right to me.
John
Bean.
"People who are willing to trade their freedom for·security deserve neither and will lose both." Benjamin Franklin
they keep changing like crazy.· the newest is 3.2.3·· It is on the SX downloads page.
It's Only A Stupid Question If You Have Not Googled It First!!
Bean.
Thanks, I downloaded the latest version and yes, the problem I described has been fixed. The name of the installation file I downloaded shows file version 3.53.346.0, and the About box in the environment shows program version 3.2.3.· You mention yet another number (1.51.03), but I'm not sure where to find that one. Where do I look?
-John
Then click on the IDE version # line and it will cycle through the version numbers of the componets.
The third version # list should be "SXB Ver: 1.51.03"
Bean.
-John
