masking
dose any one have a chart or a link on how to mask a random number to a number range?
like this
I need to mask one variable to numbers between 0 and 7 and one from 0 to 14.
should I use the max command?
any ideas?
Post Edited (Special_K) : 11/11/2006 4:51:44 AM GMT
like this
drive = randnum & %1111 'mask off number between 0-15
randnum = drive MAX 7
any ideas?
·· The following thread has code for generating random numbers in a range.· The trick is in using the modulus operator.· Take care.
http://forums.parallax.com/showthread.php?p=522895
but I am getting numbers way out of range
drive can equal 100
This displays the value of drive as a binary number. "100" in binary is the value four which is a correct value for what you're trying to do.
·········· drive·=·randnum·//·DDIR······'ddir·=·7
Modulus is the remainder of a division therefore the remainder of a division by 7 is 0 to 6 inclusive.
Try setting DDIR to 8 your results will be 0 to 7 inclusive and thats what the ·"BRANCH" instructions looking for.
Of course your code uses the "Forward" label 4 times so it won't matter too much in this example, but if you reuse your code elsewhere or decide to trim down you BRANCH statement it will give you problems.
Have Fun
TR
Post Edited (TechnoRobbo) : 11/15/2006 11:33:28 AM GMT
I found the BIN thing last night and changed it forgot to update.
I will change the ddir to equal 8.
The branch code has forward 4 times to stack the deck because I want the random motion to be more forward rather then in circles.
