programming error msg "programming failed"
what event promps the display "programming failed" w/ sk-key v3.10.
the message comes up after the device operation msg box displays programming... and the progress bar is full.
engineer, fireman, bowler, father, WoW addict [noparse];)[/noparse]
I experienced this error when I once tried to program an SX28 with a DEVICE SX48 directive in the source code. In this case, the SX-Key IDE tries to write into program memory which is not available on an SX28 (or smaller) which causes the error message.
Greetings from Germany,
G
I'm glad that this was a hit
G
