uMMC and a Stamp?
![Bill Chennault](https://forums.parallax.com/uploads/userpics/820/n25YAQT2TKN7D.jpg)
All--
Have you tried--or thought about--using the uMMC storage unit (FAT16/32 SD or MMC card) with a Stamp? In my inexperience, they LOOK simple to use.
Here is a link to the pdf description at Active Robots . . .
http://www.active-robots.com/products/accessories/data-storage/ummc-datasheet.pdf
I am interested in the local storage of large tables indicating joint positions and other related data. Tell me what you think about the applicability of this product.
--Bill
You are what you write.
--Bill
· I sell the SD Data Logger www.sddatalogger.com . It may work for what you are trying to do.
· Here is a link to the manual http://user.pa.net/~bean/sddatalogger/SD%20Data%20Logger.pdf
· Your application sound interesting, if you want I can spot you one. If it works for you, you can pay for it, if it doesn't just return it. Send me a PM (private message) with your address if you want to try it.
How much data do you need to store ? It is text or values ? How do you want to retrieve it ?
Bean.
"People who are willing to trade their freedom for·security deserve neither and will lose both." Benjamin Franklin
I talked to Bean offline . . . well, it was actually online, but that's not important right now. Short story even shorter: I am buying one of his SD Data Loggers.
--Bill
It's on it way...
Bean.
Got it today!
First two dumb questions (maybe thre) . . .
1) Will the BOE power your SD Data Logger directly or is there circuitry on your site?
2) I thought I had something at home that would let me format the 32MB SD card. Of course, I don't and my wife doesn't have anything at work and I don't think I do, either. What do I need to get?
I am excited about it . . . the SD Data Logger is certainly a professional looking effort!
--Bill
· You can plug the cable directly into the BOE servo connectors. That will both power the module and give you communications.
· The memory card is already formatted and "ready to go".
· If you do connect thru the servo headers, make sure you put the power switch in position 2 to apply power to the data logger.
P.S. The "Active" LED flashes when power is applied. Then is only on while a file is open.
Bean.
Post Edited (Bean (Hitt Consulting)) : 11/14/2006 12:23:30 PM GMT
Thank you very much.
I am an accomplished programmer and at the end of my professional career. I think microcontrollers were invented during my 3+ decades in this business . . . and I missed out! (At the beginning, my big goal in life was to become a production assembly-level programmer. I am SO glad I did not achieve that goal!)
Anyway, I am working my way through WAM and several other project books from Parallax. The coding, of course, is simple, but the I/O and electronics are almost foreign to me and I pick up a tidbit with each experiment. (I did do some "microcontroller" based stuff about 30 years ago, so I am familiar with the part that has not dimmed with age.)
But, the next free moment I get, I am plugging your SD Data Logger in and play with it!
--Bill
