Time calculators — Parallax Forums
Time calculators
metron9metron9 Posts: 1,100
edited 2006-11-12 05:25 in General Discussion
Anyone have a link to a windows calculator that has the ability to input processor clock speed, clock cycles used, and output the number of mS, uS or nS
example: 20MHZ clock divided by 20,000 cycles = 1mS instead or 1,000 because I have a hard time thinking about small numbers.
When I want to know how long a pause routine will take if it takes 756 cycles at 20mhz
I take 20,000,000 divide by 756 = 26,455.026455......
I wold rather see xx uS
Think outside the BOX!
    edited 2006-11-09 15:29
    That 26.455.02 etcetera is cycles per second -- just use x -1 and it is 37.8 microseconds.
    I have a RPN calculator on my Palm Zire and it has three outputs: Traditonal Floating Point, Engineering, and Scientific.
    Engineering Output keeps everything to 10x3, 10x6 or 10x-3, 10x-6 and so on. I suspect that is the best you can do.
    Look for a 'shareware' calculator that you can test.It also does HH.MM.SS calculators and much more.
    Try www.nthlab.com if you have a Palm or other PDA.
    The Chinese drive me nuts as everything is in 4s. 10,0000 equals one hundred thousand. One million is 10,0000,0000.
    Recently there was a huge stock market disaster as an order from the U.S.A was placed and discover to be off by a factor of 10.
    The broker tried to buy 10 times more stock than the customer wanted.
    "If you want more fiber, eat the package.· Not enough?· Eat the manual."········
    ···················· Tropical regards,····· G. Herzog [noparse][[/noparse]·黃鶴 ]·in Taiwan
  • UnsoundcodeUnsoundcode Posts: 1,532
    edited 2006-11-12 00:06
    Hi metron, I had a little fun doing this, it's not perfect but check it out.
    Jeff T.
    exe
    295K
    CPS.exe 294.8K
  • metron9metron9 Posts: 1,100
    When originally posted this I decided on the drive to work to use realbasic to make a calculator exactly as you have made it. Course by the time I got home from work I just never got around to doing it. Thanks, it's a handy tool, I like it.
