Newbie - Trying not to fry it.
Can I use 1/4 watt 10K ohm resistor instead of 1/8 Watt ? on the 24LC256 EEPROM ? What would be the effect ?
Also, would this work for a power supply for the Propeller ? It's +3.3v
They say you plug it on the breadboard.
cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&ih=006&sspagename=STRK%3AMEWN%3AIT&viewitem=&item=160036249360&rd=1&rd=1
There is a +5v one also could you use it for higher voltage components, and use the 3.3 for the chip ?
I'm trying not to fry my chip as I dont know much on what I'm doing. They said not to
cut the ends of the powercord from radioshack, cause it would not work at 4.6v - the current
would be to rough.
Post Edited (Areal Person) : 11/8/2006 9:11:51 PM GMT
would be to rough.
Yes, you can use that for the propeller, it would be just fine because it says that the power supply uses a 3.3 volt regulator, which would stablize the voltage from the wall wart.
Yes you can, but just be careful NOT to put the 5v to the propeller. I'm not sure how much you know about electronics, but if you are going to use a 3.3v and 5v power supply to run the propeller and some other things, you have to connect the ground pins from both power supplies to make sure that there is proper communication between anything that uses the 5v to talk to the propeller.
Also, check this out, may save you some time: http://forums.parallax.com/showthread.php?p=585920 (this explains how to have the propeller input a 5v signal)
while alive = 1
wakeup
program(propeller)
eat(3)
sleep(7)
www.sparkfun.com/commerce/product_info.php?products_id=114
