Full Duplex Serial — Parallax Forums
Full Duplex Serial
SailerManSailerMan Posts: 337
edited 2006-11-09 03:31 in Propeller 1
I currently have my SX28 talking to my Propeller using the Propellers (bs2 Serial Object) I then decided to try the Full Duplex Serial and the poop has hit the fan. I can't seem to get anything working correctly.· I'm Using mode %1010 on the Propeller side.
Does anyone know what could be happening? Any working sample code between the Prop and the SX28 would be apreciated... Just to make sure I have my setup right.
Thanks in Advance,
Eric
  • T ChapT Chap Posts: 4,260
    edited 2006-11-08 19:58
    If you posted the code section, someone may see the poblem easily. Full dup is very easy to send to the SX.
  • SailerManSailerMan Posts: 337
    edited 2006-11-08 20:21
    I'm using the standard SerOut and SerIn Command but my Baud rate on the SX is unusual because of interupts.. If I am sending and Receiving on the SX28 at 9600 Baud... ( TX = SX Pin RB.0 to Prop Pin 1) and (RX- SX Pin RB.1 to Prop Pin 2) How should I set up the Serial Full Duplex on the Prop Side...Specifically the Mode. Is there anything else I need to know about besides the TX and RX Commands. Do I really need to FLush the RX Buffer.
    I'd enclose my code but it's gettting a little hard to read... I need to clean it up.
    but if It was working with the spin code (BS2 Object) I can't see why it will not work with the Full Duplex ASM code.
    edited 2006-11-09 00:06
    Is there some particular reason why you're using opposite modes (inverted/non-inverted) on receive and transmit? Normally, mode %0010 (or %0000) would be used if you're not using an RS232 adapter that inverts the data. The BS2 serial routines for the Propeller don't even support open-source/drain mode and specify inverted mode with a value of 0 which is opposite from the mode bits with the FullDuplexSerial routines.
    edited 2006-11-09 00:12
    ok...Here is the best I can do for the code.
    Here is the Prop Code
    Con
            _clkmode        = xtal1 + pll16x
            _xinfreq        = 5_000_000
            SerialOutputPin = 17
            SerialInputPin = 18
    Var
            Long MicroSecond
            Byte Ramp
            Long LeftEncoder,RightEncoder
            long DeltaL,DeltaR
    Obj
      Debug : "TV_Text"
      Serial : "FullDuplexSerial"
    Pub Main|LastLeft,LastRight,Command,Dummy
      MicroSecond:= clkfreq / 1_000_000
      Serial.Start(SerialInputPin,SerialOutputPin,%1010,9600)
      Debug.start(12)
      DirA[noparse][[/noparse]0]:=0
      Repeat
          Command:=254
          Serial.TX(Command)
          LeftEncoder:=Serial.RX
          RightEncoder:=Serial.RX
          Command:=170
          Serial.TX(Command)
          Serial.TX(0)
          Serial.TX(RAMP)
          Ramp+=1
          DeltaL:=(~LeftEncoder)
          DeltaR:=(~RightEncoder)
          Display
    Pub Display
        DEbug.Out(1)
        Debug.Str(String("      ",13))
        Debug.Str(String("LeftEncoder ="))
        Debug.Dec(DeltaL)
        Debug.Str(String("RightEncoder="))
        Debug.Dec(DeltaR)
        Debug.Str(String("RANGE="))
        Debug.Dec(RAMP)
        Debug.Out(1)
    and Here is the SX/B Code
    DEVICE          SX28, OSCHS2, TURBO, STACKX, OPTIONX, BOR42
    FREQ            50_000_000
    ID  "ENCODER"
    Baud  CON "N14585"
    PWM_Count VAR BYTE
    PWM_Values VAR BYTE (4)
    SerialData VAR BYTE
    DataInPin   Var     RC.0
    DataOutPin  Var  RC.1
    EncPort         Var     RA
    Index       Var    Byte
    EncodersOld      VAR    byte
    EncodersNew      VAR    byte
    Encoder_A_Count  VAR    Byte
    Encoder_B_Count  VAR    Byte
    tmpB1           VAR     byte
    tmpB2           VAR     Byte
    Temp   Var  byte
    Value   Var  Byte
    Channel      Var  Byte
    Command   Var  byte
    INTERRUPT
    ISR_Start:
     EncodersNew = EncPort
     TmpB1 = EncodersOld XOR EncodersNew
     TmpB2 = TmpB1 << 1
     TmpB1 = TmpB1 OR TmpB2
     EncodersOld = EncodersOld << 1
     EncodersOld = EncodersOld XOR EncodersNew
     IF TmpB1.3 = 1 THEN
         IF EncodersOld.3 = 1 THEN
       INC Encoder_A_Count
         ELSE
       DEC Encoder_A_Count
          ENDIF
    Else
     Asm
      Nop
      Nop
      Nop
      Nop
     EndAsm
      ENDIF
     IF tmpB1.1 = 1 THEN
         IF EncodersOld.1 = 1 THEN
            INC Encoder_B_Count
          ELSE
            DEC Encoder_B_Count
         ENDIF
     Else
     Asm
      Nop
      Nop
      Nop
      Nop
     EndAsm
     ENDIF
     EncodersOld=EncodersNew
    ASM
          ' ** Setup variables
     MOV __PARAM1,#4        ' (2) Number of bits per port
     MOV __PARAM2,#1        ' (2) OR Mask for turning a bit ON
     MOV __PARAM3,#254      ' (2) AND Mask for turning a bit OFF
     INC PWM_Count          ' (1) Adjust the PWM count
                            '     If the PWM value for each channel is
                            '     less than PWM_Count then it should
                            '     be high, othewise it should be low
     MOV __PARAM4,PWM_Count ' (2) Make copy of PWM_Count in global memory
     MOV FSR,#PWM_Values    ' (2) Set FSR to address of 1st element of PWM values
    :NEXT_BIT
             ' ** First do port B bits
      CJA IND,__PARAM4,@:MAKE_HIGH_B  ' (5/7) If this element is above PWM_Count
                                                   ' Then jump to MAKE_HIGH_B
      AND RB,__PARAM3          ' (2) Value is below or equal to PWM_Count so
                                         '      make it low.
      JMP @:DONE_BIT_B     ' (4) Jump over MAKE_HIGH code
    :MAKE_HIGH_B
      OR RB,__PARAM2       ' (2) Value is above PWM_Count so make it HIGH
      NOP                  ' (1) Waste time
    :DONE_BIT_B
      STC                  ' (1) Need to shift a 1 into AND mask value
      RL __PARAM3          ' (1) Shift AND mask value
      CLC                  ' (1) Need to shift a 0 into OR mask value
      RL __PARAM2          ' (1) Shift OR mask value
      Inc FSR
     DJNZ __PARAM1,@:NEXT_BIT     ' (3/5) Repeat until done
    ENDASM
    RETURNINT
    GetEncoders Sub 0
    ChangePWM Sub 0
    SendCommand Sub 1
    GetData Func 1
    PROGRAM Start NOSTARTUP
    Start:
      EncodersOld = EncodersNew
      OPTION = $80
    Main:
    TRIS_B=%00000000
    Tris_C=%00000000
    Input DataInPin
    Output DataOutPin
    Encoder_A_Count=0
    Encoder_B_Count=0
    Do
      RC.4=1
        Command=GetData
     RC.4=0
     RC.7=1
     RC.6=1
     If Command=254 then GetEncoders
     If Command=170 then ChangePWM
    Loop
    GetEncoders:
       Pauseus 100
      SendCommand Encoder_A_Count
      SendCommand Encoder_B_Count
      Encoder_A_Count=0
      Encoder_B_Count=0
    Return
    ChangePWM:
      Channel=GetData
      Value=GetData
       If Value>128 Then
       PWM_Values(1)=255-Value
       PWM_Values(0)=0
       High RC.7
       Low  RC.6
      Else
       High RC.6
       Low  RC.7
       PWM_Values(1)=0
       PWM_Values(0)=Value*2
      Endif
    Return
    SendCommand:
     SerOut DataOutPin,Baud,__Param1
    Return
    GetData:
     SerIn  DataInPin,Baud,__Param1
    Return __Param1
    My SX Baud Rate is to compensate for the ISR
    Basically The SX counts encoder pulses and creates PWM on·2 channels.
    The Propeller Sends Command (254) to read the Encoders, and Command (170) to set the PWM Channel (0 or 1) + Duty (0-255)
    I am noticing that I can Set the Motor Speed. But I can't read the Encoders. Hmmm....
    Any help like always would be greatly appreciated
    Eric
    Post Edited (SailerMan) : 11/9/2006 12:51:12 AM GMT
    edited 2006-11-09 03:08
    Did you try using 0,1, or 2 instead of %1010? Start with 0
    I could be off but I didn't think there were any other options besides 0 1 2 and maybe 3
    Post Edited (originator99) : 11/9/2006 3:14:24 AM GMT
    I Changed my Baud declaration to T-True and used Serial.Start(SerialInputPin,SerialOutputPin,%0000,9600)
    All is good now... I hope!! [noparse]:)[/noparse]
    Eric
